MHB Linear combination of sine and cosine function
The discussion focuses on finding the minimum values of the function \(6\sin x + 8\cos x + 5\) and its subsequent transformations. The minimum of the original function is identified as \(-5\), leading to the minimum values of the derived functions: \((6\sin x + 8\cos x)^2 + 5\) is \(5\), \((6\sin x + 8\cos x)^3 + 5\) is \(-995\), and \((6\sin x + 8\cos x)^4 + 5\) is again \(5\). The discussion highlights the importance of correctly applying trigonometric identities to simplify the problem. Overall, the thread emphasizes the necessity of careful reasoning in mathematical problem-solving.
anemone
MHB
POTW Director
Hi MHB! I recently came across a problem and I was thinking most likely I was missing something very obvious because I couldn't make sense of what was being asked, and I so wish to know what exactly that I failed to relate.
Question:
Find the minimum of $6\sin x+8\cos x+5$. Hence, find the minimum of $(6\sin x+8\cos x)^2+5,\,(6\sin x+8\cos x)^3+5$ and $(6\sin x+8\cos x)^4+5$.
It is important to stress that students are expected to solve it via trigonometry route but not other methods.
I would feel the "hence" implies that the first part of the question greatly help to reach to the answers for the subsequent parts of the problem, but not that I could see it...therefore, any insight would be helpful and thanks in advanced for the help!
Mathematics news on Phys.org
If f(x) has minimum m at x= x0 then f(x)+ 5 has minimum m+ 5 at x0, f(x)^2+ 5 has minimum m^2+ 5 at x= x0, and, generally, f(x)^n+ 5 has minimum m^n+ 5 at x= x-x0.
Country Boy said:
If f(x) has minimum m at x= x0 then[/color] f(x)+ 5 has minimum m+ 5 at x0, f(x)^2+ 5 has minimum m^2+ 5 at x= x0[/color], and, generally, f(x)^n+ 5 has minimum m^n+ 5 at x= x-x0.
That is not true. For example, the function $f(x) = \sin x$ has minimum $m = -1$ at $x_0 = \frac{3\pi}2$. But $f(x)^2 + 5$ does not have minimum $m^2+5 = 6$ at $x = x_0$. Instead, it has minimum $5$ at $x = 0$.
Argh!(Headbang) I couldn't believe how I overlooked something so trivially simple in order to deduce the minimum of the other functions! Once we rewrite $6\sin x+8\cos x+5=10\sin \left(x+\tan^{-1}\dfrac{4}{3}\right)+5$, we know the minimum can be attained at $-5$, and so the minimum values of
$(6\sin x+8\cos x)^2+5=\left(10\sin \left(x+\tan^{-1}\dfrac{4}{3}\right)\right)^2+5$ is $0+5=5$,
$(6\sin x+8\cos x)^3+5=\left(10\sin \left(x+\tan^{-1}\dfrac{4}{3}\right)\right)^3+5$ is $(-10)^3+5=-995$,
$(6\sin x+8\cos x)^4+5=\left(10\sin \left(x+\tan^{-1}\dfrac{4}{3}\right)\right)^4+5$ is $0+5=5$.
Sorry for asking something so simple!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
