Linear Differential Equation in Strange Form
In summary, the given differential equation cannot be put into standard form as it is not a linear equation. However, it can be solved by treating y as the independent variable and x as the dependent variable, and using an integrating factor of 1/y.
Gooolati
ydx - 4(x + y^6)dy = 0
Need to get into the form of dy[tex]/dx[/tex] + f(x)y = G(x)
(Standard Form)
ydx = 4(x + y^6)dy
y = 4(x + y^6) dy/dx
y[tex]/4(x + y^6)[/tex] = dy/dx
then I don't know how to get it in the Standard form
All help is appreciated, thanks!
You can't. That's not a linear equation to begin with ([itex]y^6[/tex] is not linear) and you can't just force it into "standard form" for a linear equation.
Oh I can see that now! I just wonder why it's in the Linear Equations section haha.
See , sometimes in order to solve problems of this sort, we treat y as the independent variable and x as the dependent variable and convert it into a linear equation in the variable x.So now in place of dy/dx we have dx/dy and then we solve it using the integrating factor which in this case is 1/y.
Try dx/dy -4/y*x = 4y^6
FAQ: Linear Differential Equation in Strange Form
What is a linear differential equation in strange form?
A linear differential equation in strange form is a type of differential equation in which the dependent variable and its derivatives are multiplied by some functions that are not necessarily continuous or differentiable. The equation takes the form of y' = f(x)y + g(x)y2, where y is the dependent variable, y' is its derivative, and f(x) and g(x) are functions of the independent variable x.
How is a linear differential equation in strange form different from a standard linear differential equation?
The main difference between a linear differential equation in strange form and a standard linear differential equation is the presence of non-continuous or non-differentiable functions in the equation. In a standard linear differential equation, the functions are usually continuous and differentiable.
What are some examples of linear differential equations in strange form?
Some examples of linear differential equations in strange form are: y' = x2y + cos(x)y2, y' = exy + ln(x)y2, and y' = sin(x)y + sqrt(x)y2.
How do you solve a linear differential equation in strange form?
To solve a linear differential equation in strange form, you can use the method of separation of variables or the method of integrating factors. Both methods involve manipulating the equation to separate the variables and then integrating to find the solution.
What are the applications of linear differential equations in strange form?
Linear differential equations in strange form have applications in various fields such as physics, engineering, and economics. They can be used to model real-life situations involving changing quantities, such as population growth or chemical reactions. They also have applications in control systems, where they are used to design controllers for systems with nonlinear dynamics.
