Linear Equations & Quantum Mechanics
In summary: Instead, the state at a later time will be a superposition of energy eigenstates, including the initial state |a> as one of the terms.In summary, the Schrodinger equation can give a superposition of two states, x1 and x2, at time0. As the equation evolves over time, the solution at time1 will still be a superposition of x1 and x2, but the superposition may have different coefficients. This applies to cases where the states are energy eigenstates and when they are not.
StevieTNZ
1,934
883
Say we can find a solution to the Schrodinger equation, which gives a superposition of two states x1 and x2. Say this occurs at time0.
The equation evolves over time, say to time1.
At time1, are x1 and x2 (the same states found by solving the Schrodinger equation at time0) still superposition states in a solution to the Schrodinger equation at time1?
Yes, since as soon as the superposition is reconciled as a definite result, the wavefunction no longer applies.
If we can write our initial state as
[tex]|\psi(t=0)>=A|1>+B|2>[/tex]
where |1> & |2> are our orthogonal states.
If we want the solution at a later time, we then apply the time evolution operator to the system:
[tex]|\psi(t)>=e^{iHt/\hbar}|\psi(0)>[/tex]
So, if |1> and |2> are both eigenfunctions of H, the Hamiltonian, the solution at time t will remain a superposition of |1> and |2>, but can be a different superposition:
i.e.
[tex]|\psi(t)>=A'|1>+B'|2>=Ae^{iE_1t/\hbar}|1>+Be^{iE_2t/\hbar}|2>[/tex]
Notice however:
If |1> and |2> are not energy eigenstates, then we need to expand them in terms of energy eigenstates before we apply the time evolution operator. The resulting state at time t will still be able to be written as a superposition of energy eigenstates, but not necessarily as a superposition of |1> and |2>.
I am not sure what you are saying.
i.e.
Just so I follow, the states |1> and |2> are the same at t=0 and t=1, just that the solution to the equation at t=1 will look different? i.e you add [tex]e^{iHt/\hbar}[/tex] to the front of each state in the solution at t=1.
Yes,
If the state |a> is an energy eigenstate, at t=t1, The state |a> will be the same (up to the phase factor [itex]e^{iE_at/\hbar}[/itex] )
However, if the state |a> is not an energy eigenstate, then the time evolution operator [itex]e^{iHt/\hbar}[/itex] does not give just a phase factor like above.
FAQ: Linear Equations & Quantum Mechanics
What are linear equations in quantum mechanics?
Linear equations in quantum mechanics are mathematical expressions that describe the behavior and interactions of quantum particles, such as electrons and photons. These equations, such as the Schrödinger equation, are used to calculate the probabilities of different outcomes in quantum systems.
How are linear equations used in quantum mechanics?
Linear equations are used in quantum mechanics to describe the evolution of quantum systems over time, as well as the properties and behavior of individual particles. They are used to calculate the probabilities of different outcomes and make predictions about the behavior of quantum systems.
What is the relationship between linear equations and quantum states?
In quantum mechanics, linear equations are used to describe the state of a quantum system. The solutions to these equations represent the possible quantum states of a system, and the coefficients in the equations represent the probability amplitudes of these states.
How are linear equations derived in quantum mechanics?
Linear equations in quantum mechanics are derived from the principles of quantum mechanics, such as the uncertainty principle and the wave-particle duality of matter. They are also influenced by classical physics and mathematical concepts, such as linear algebra and differential equations.
What are some real-world applications of linear equations in quantum mechanics?
Linear equations in quantum mechanics have a wide range of applications in areas such as quantum computing, cryptography, and quantum information theory. They are also used in the development of technologies such as quantum sensors and quantum communication systems.
