Linear Expansion - Finding temperature
The discussion focuses on calculating the change in temperature required for one ring's outer radius to match another ring's inner radius. The initial approach involved using two equations related to linear expansion but faced issues with too many unknowns. A proposed equation was criticized for being nonsensical due to redundancy. Participants emphasized the need for clarity in defining variables and suggested posting the equations for verification. The conversation highlights the importance of precise mathematical formulation in solving thermal expansion problems.
JoeyBob
See attached
change length= a*original length * change in temp
So if I am understanding the question correctly, I need to find the change in temperature that causes one rights outer radii to be the same as another rings inner radii.
Now what I tried is two equations
change length_1= a_1*original length_inner * change in temp
change length_2= a_2*original length_outer * change in temp
But the problem is that there is one too many unknowns here - i don't know the temp, change in L_1 or change in L-2. Either there's another equation I am missing or I am using the wrong approach.
Okay I think I found the equation I was missing.
L_1+change in L_2 = L_2 + change in L_2
The answer I got was only a bit off from the right answer, probably from rounding or something.
That equation makes no sense since you have "change in L_2" on both sides. What did you mean, in terms of the given variables ri etc? Use α1, α2 for the coefficients.
Please post your answer and working so that we can check whether it is just rounding error.
It looks like a typo.
Its a typo. change in L_1.
The 3 equations are correct?
Impossible to say without definitions of the variables.
This is certainly correct:
find the change in temperature that causes one ring's outer radius to be the same as the other ring's inner radius.
But you have not posted an equation that expresses that in terms of r1, r2, α1, α2 and Δθ.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
