Linear expansion physics homework
In summary, the conversation revolved around a question regarding the radius of a weather balloon at lift off. The balloon is designed to expand to a maximum radius of 26m when in flight at its working altitude with a pressure of .026 atm and a temperature of 229K. The balloon is filled at atmospheric pressure and a temperature of 434K. The solution involves using a gas equation to relate pressure, volume, and temperature.
Jake4
111
A weather balloon is designed to expand to a maximum radius of 26m hen in flight at its working altitude where the air pressure is .026 atm and the temperature is 229K
If the balloon is filled at atmospheric pressure and 434K, what is its radius at lift off?
We learned linear expansion in class, and all about pressures and changes in pressure. However I don't think we ever went over anything of this sort.
Thanks for the help guys!
exam tomorrow!
no one? :(
Even just help with the relevant equations?
It seems you need a gas equation which relates P, V, and T. Seen any good ones lately?
Too funny!:smile:
Hello there! As a fellow scientist, I would be happy to assist you with your linear expansion homework problem. The first thing we need to do is use the ideal gas law, PV = nRT, to find the initial volume of the balloon. We know the pressure (1 atm), temperature (434K), and the gas constant R, so we can solve for the initial volume (V1).
Once we have the initial volume, we can use the formula for linear expansion, ΔL = αLΔT, to find the change in length (ΔL) of the balloon. In this case, the change in length will be equal to the change in radius (ΔR) since we are dealing with a spherical balloon.
We know that at lift off, the balloon will be at its maximum radius of 26m. So we can set up the equation as follows:
26m = V1 + ΔR
Solving for ΔR, we get ΔR = 26m - V1
Now we can plug in the values we have and solve for the change in length (ΔL):
ΔL = αLΔT = α(26m - V1)
Next, we need to find the coefficient of linear expansion (α) for the material of the balloon. This can be found in a table or given in the problem. Once we have the value for α, we can plug it in and solve for ΔL.
Finally, we can use the formula for linear expansion again to find the final radius (R2) of the balloon at lift off:
R2 = R1 + ΔL
Where R1 is the initial radius of the balloon when it was filled at atmospheric pressure.
I hope this helps and good luck on your exam tomorrow! Remember to always double check your units and equations to make sure they are consistent. Happy studying!
FAQ: Linear expansion physics homework
What is linear expansion?
Linear expansion is the phenomenon where an object increases in length when heated and decreases in length when cooled. This is due to the increase or decrease in thermal energy causing the atoms in the object to vibrate and take up more or less space.
What is the formula for linear expansion?
The formula for linear expansion is ΔL = αLΔT, where ΔL is the change in length, α is the coefficient of linear expansion, L is the original length, and ΔT is the change in temperature.
What is the coefficient of linear expansion?
The coefficient of linear expansion is a constant that represents the amount of length an object will expand or contract per unit length per degree Celsius. It is different for each material and can be measured experimentally.
How do you calculate the change in length of an object due to linear expansion?
To calculate the change in length, you can use the formula ΔL = αLΔT, where ΔL is the change in length, α is the coefficient of linear expansion, L is the original length, and ΔT is the change in temperature. You can also use a calculator or a spreadsheet to make the calculation easier.
What are some real-life examples of linear expansion?
Some examples of linear expansion in everyday life include the expansion of metal bridges in hot weather, the contraction of train tracks in cold weather, and the use of expansion joints in buildings to allow for the expansion and contraction of materials. It is also responsible for the cracking of sidewalks and the bending of railroad tracks in extreme temperatures.
11K
