Linear Inverting Amplifier Help
In summary: It will be clipped to +/- 5 V.In summary, the linear inverting amplifier has a gain of 35 dB or e^(7/4) V/V and its output is limited to a range of -5V to 5V. If the input voltage is -8.0V, the output will be clipped to 5V due to exceeding the output range.
Fizzill
A linear inverting amplifier has these characteristics:
-5.0V < vo < +5.0V Av=35 dB
The output rails at -5.0V and +5.0V That is, the amplifier outputs no voltage larger in magnitude than 5.0V.
What is the gain in V/V?
What is the output if vi=-8.0V?
Av = vo/vi
Av = 20log|Av|
Av = 35db
35/20 =log|Av| => Av = e^(7/4) V/V
vo = Av * vi => (-8.0V) * e^(7/4)
but since this is out of the -5V to 5V range, it would just be 5V
Does this look right?
Av = vo/vi
Av = 20log|Av|
Av = 35db
Watch it! The log is base 10, not base e. And you should be able to write a numerical value for a result.
Yup. The input already exceeds the output range and the gain is greater than unity.
Related to Linear Inverting Amplifier Help
1. What is a linear inverting amplifier?
A linear inverting amplifier is an electronic circuit that amplifies an input signal while inverting its polarity. It is commonly used in audio and communication systems to increase the amplitude of a signal.
2. How does a linear inverting amplifier work?
A linear inverting amplifier consists of an operational amplifier (op-amp) and two resistors. The input signal is applied to the inverting input of the op-amp, and the output is fed back to the inverting input through a feedback resistor. The amplified output signal is taken from the output terminal of the op-amp.
3. What are the advantages of a linear inverting amplifier?
Some advantages of a linear inverting amplifier include high gain, low distortion, and simplicity in design. It also has a wide range of applications in different industries, such as audio, medical, and telecommunications.
4. What are the limitations of a linear inverting amplifier?
One limitation of a linear inverting amplifier is that it can only amplify signals within its power supply limits. It also requires a stable power supply and is sensitive to noise and interference. Additionally, it has a limited frequency response and can introduce phase shifts in the output signal.
5. How can I troubleshoot issues with a linear inverting amplifier?
If you are experiencing problems with your linear inverting amplifier, you can start by checking the connections and making sure they are secure. You can also try adjusting the feedback resistor to see if it improves the performance. If the issue persists, it could indicate a faulty component or a design error, and you may need to consult a professional for further assistance.
  • Electrical Engineering
