Linear momentum but quadratic kinetic energy?
In summary, the concept of "linear momentum but quadratic kinetic energy" refers to the relationship between momentum and kinetic energy in classical mechanics. Linear momentum, defined as the product of mass and velocity, is a linear function, while kinetic energy, given by the formula \( \frac{1}{2} mv^2 \), is a quadratic function of velocity. This distinction highlights how momentum scales linearly with velocity, while kinetic energy increases with the square of velocity, leading to different implications in various physical scenarios, such as collisions and the conservation laws governing them.
Rick28
Conservation of momentum and cinetic energy : I don't understand why the total kinetic energy seems to increase (or decrease) when we apply the conservation of momentum
Example with 100 kg ball at 5 m/s that go to 0 m/s when hitting a 10 kg ball.
The 10 kg ball should be at 50 m/s now, but the kinetic energy will be increased in comparision to the 100 kg ball that was previously at 5 m/s.
12.5 kJ for the 10 kg ball at 50 m/s vs 1.25 kJ for the 100 kg ball at 5 m/s
How is this possible ?
thanks
P = m.v
E = (m.v^2 ) . 1/2
no clues
That cannot happen. If you start with a false premiss you can deduce anything.
Edit: Challenge for you: what is the minimum final speed of the 100kg ball, and in which direction?
Rick28 said:
Homework Statement: Conservation of momentum and cinetic energy : I don't understand why the total kinetic energy seems to increase (or decrease) when we apply the conservation of momentum
thanks
Relevant Equations: P = m.v
E = (m.v^2 ) . 1/2
no clues
That's not possible.
In an inelastic collision momentum is conserved and some of the kinetic energy is transformed to heat, so the macroscopic kinetic energy decreases.
The opposite is not possible since it would mean that heat is completely transformed to work.
As you have computed, the kinetic energy increases in this scenario. The smaller ball bounces away from the larger more rapidly than it arrived.
In an ordinary passive encounter between two balls we expect them to slow down relative to each other as the result of an impact. We know this to be the case. It happens every time. It has to do with "entropy". Total mechanical energy tends to decrease as it is dissipated into thermal energy.
If we observe a violation of this behavior then we know that something unexpected is going on. Perhaps someone had painted the larger ball with some contact explosive so that there was a pop and a puff of smoke along with the collision. The increase in mechanical energy was balanced by a decrease in chemical potential energy.
Or perhaps this was an unfair encounter between a 100 kg spinning Beyblade [yikes!] and a 5 kg Beyblade. Linear kinetic enegy increased at the expense of the rotational kinetic energy of the objects.
Likes Philip Koeck
Seems to me the OP has made up the scenario, not realising it might violate reality.
Likes jbriggs444
