northmop
- 11
- 3
I am interested in how impulse turbines work. Supposing a mass of water (in kilograms), m, is expelled by a jet at a given velocity (in meters per second), v, its momentum (in Newton-seconds), p, is the product of these quantities: p = mv. Also, a paddlewheel’s angular momentum (in Newton-meter-seconds), L, is equivalent to the product of the mass moment of inertia (in kilogram-square meters), I, and the angular velocity (in radians per second), w: L = Iw.
My confusion has always manifested when the water hits the paddle of a motionless impulse turbine. Would the angular momentum be equivalent to the product of linear momentum and the radius of the wheel (in meters), r, at which the water hits: L = pr = mvr = Iw? Given an impulse occurs from the water of a jet on the paddle of a turbine that is not moving, would the final angular velocity of the paddlewheel be w = mvr/I?
I have another confusion. If a large mass of water hits the paddlewheel, the final angular velocity should be proportionately large. What if the tangential velocity ends up being larger than that of the water velocity? Is the maximum limit of the paddlewheel’s velocity the velocity of the impulse? For example, assume a paddlewheel at rest with I = 10.0 is hit with 100.0 kilograms of water traveling at 1 meter per second at its paddles having an average radius of 0.500 meters. The paddlewheel’s final velocity would be 5.00 radians per second with a tangential velocity of 2.5 meters per second. The paddle would be traveling over twice as fast as the water that made the impulse! Intuitively, I believe that the paddle can travel no faster than the velocity of the water. Given this upper limit of a 1 meter per second tangential velocity, would the angular velocity of the paddlewheel actually be 2 radians per second instead of 5?
Owwwwww ... my head ...
