Linear Ordinary Differential Equation: Definition
In summary, a linear differential equation is one where the dependent variable and its derivatives are only multiplied by constant multiples or functions of the independent variable, and there are no terms with a degree higher than one.
Prof. 27
50
The website says this:
"It is Linear when the variable (and its derivatives) has no exponent or other function put on it.
So no y2, y3, √y, sin(y), ln(y) etc, just plain y (or whatever the variable is).
More formally a Linear Differential Equation is in the form:
dy/dx + P(x)y = Q(x)"
My question is whether what makes it a linear differential equation the fact that nothing on the other side of the equals sign from Q(x) has any degree higher than one or whether it is a linear differential equation because the differential doesn't have a degree higher than 1; for example, is this a linear differential equation?
dy/dx + y^3 = Q(x)
What about this one?
dy/dx + P(x)y = Q(x)^2
http://en.wikipedia.org/wiki/Linear_differential_equation
http://www.mathsisfun.com/calculus/differential-equations.html
Note: Sorry on the title. I meant Linear Ordinary Differential Equation. Partial should not be in there.
Maybe a better way to define a linear differential equation is that it will consist only of a linear combination of the dependent variable and its derivatives. In other words, an equation that consists of either a sum of constant multiples of y, y', y'', etc. or a sum where y, y', y'' etc. are multiplied by function of the independent variable.
dy/dx + y^3 = Q(x)
No, not linear, because of the y3 term.
Yes, linear. It doesn't matter that y is multiplied by P(x) or that we have [Q(x)]2.
I removed "Partial" from the thread title.
Likes Prof. 27
Thanks for the help Mark44. I understand now.
Related to Linear Ordinary Differential Equation: Definition
What is a linear ordinary differential equation?
A linear ordinary differential equation is a mathematical equation that describes the relationship between a dependent variable and its derivatives with respect to an independent variable. It is called "linear" because it involves only linear terms, meaning that the dependent variable and its derivatives are raised to the first power.
How is a linear ordinary differential equation different from a non-linear ordinary differential equation?
A non-linear ordinary differential equation is an equation that involves non-linear terms, meaning that the dependent variable and its derivatives are raised to powers other than one. This makes the solution process for non-linear equations more complex and often requires numerical methods, while linear equations have analytical solutions.
What are some real-life applications of linear ordinary differential equations?
Linear ordinary differential equations are used in many areas of science and engineering to model various phenomena, such as population growth, radioactive decay, and electrical circuits. They are also commonly used in physics, chemistry, and economics to describe the behavior of physical systems.
What is the order of a linear ordinary differential equation?
The order of a linear ordinary differential equation is determined by the highest derivative that appears in the equation. For example, an equation with only the first derivative of the dependent variable is a first-order differential equation, while an equation with the second derivative is a second-order differential equation.
How do you solve a linear ordinary differential equation?
The general solution to a linear ordinary differential equation can be found by using various techniques, such as separation of variables, variation of parameters, and the method of undetermined coefficients. The specific method used depends on the form of the equation and any initial or boundary conditions that may be given.
