MHB Linear profit, graphs and equations.
  • Thread starter Thread starter nihil404
    Graphs Linear
The discussion focuses on solving a profit maximization problem for a video-on-demand service, specifically regarding HD and SD subscriptions. Participants express confusion over interpreting the problem and setting up the necessary equations for graphing and calculations. Key points include understanding that HD subscriptions are twice as profitable as SD subscriptions and incorporating existing customer counts into the calculations. The constraints involve the maximum number of IO streams a server can handle and the leasing costs associated with each subscription type. Clarification is sought on whether the £100 bandwidth limit is total or per customer, which impacts the overall calculations significantly.
nihil404
I have no clue how to interpret this problem and where to start to get my values to plot my graphs and get my x, y and etc values as there is too much going on.
Can someone shed some light of how to do this problem?
I am not sure if is this how I solve this:
How do I find that the HD subscriptions is twice as profitable?
And what the HD and SD customers existing customers have to do with the problem?
IO streams = 200
HD stream = 4 = x
SD stream = 1 = y
4x + 1y = 200
bandwidth cost
1.50 HD x
0.75 SD Y
1.5x + 0.75y = 100
Lease cost =80
HD = 1 x
SD = 0.75y
1x + 0.75y = 80Am I doing the correct calculations?
Thank you very much in advance for any help.You are to help a popular online VOD service maximise their profits by advising the company’s sale team on set ‘sales targets’ for “HD single screen” subscriptions and “SD single screen” subscriptions given that it is 2 times more profitable to sell SD single screen subscriptions than HD single screen ones.
It must also be noted that the company must honour its existing HD single screen (5) and SD single screen (10) subscribers.
Being an online company profits increase linearly in relation to the number of servers running. In this instance we will only look for the costings of running a single server. That being said, due to hardware limitations, a server can only stream 200 IO streams, where a HD stream consumes 4 IO streams and a SD stream only consumes 1 IO stream.
In terms of bandwidth cost, we have a simple contract that provides the first £100 worth (per month) of bandwidth free, after which the cost for bandwidth significantly increases such that users do not exceed this free £100 limit. It is to be noted that on average the bandwidth consumption (per month) of a typical HD subscription never exceeds £1.50 with a similar case for SD subscription being £0.75.
Finally - in addition to the above, it must also be noted that this company is a daughter company from which we lease all our content from our parent company. The costs of the leases are £1 (per month) for HD subscription and £0.75 (per month) for SD subscription. Our aim is not to exceed £80 of leasing cost.
Mathematics news on Phys.org
The way you have set this up is very confusing! You write
HD stream = 4 = x
when, in fact, "4" is a coefficient of x, not a value of x. You ask
You don't! You are told that
in the first sentence of the problem.
And what the HD and SD customers existing customers have o do with the problem?
They must be included in the "hardware limitations".
You are told
So, letting x be the number of new HD streams and y the number of new SD streams, 4(x+ 5)+ (y+ 10)= 4x+ y+ 30<= 200 or 4x+ y<= 170.
So x+ 0.75y<= 80
You want to maximize 2x+ 2 subject to those constraints.
The part I can't make sense of is
Is the
per customer or total? I first read it as if it were per customer but if that is the case, the "
£1.50" and
"£0.75" are so low compared to the "£100" that it is irrelevant. If it is total, then we have the additional constraint "0.75y+ 1.5x<= 100".
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
