Linear programming problem (simplex algorithm)
In summary: The algorithm stops when it reaches a local optimal solution, which may not necessarily be the best solution for the entire problem.
SillyBen
Can anyone help me to solve that problem ? I would really appreciate
For the linear programming problem P1 :
Max z = 2 + x1 - 2x4
x2 = 1 - x4
x3 = 0 - x1 - x4
xi \(\displaystyle \ge\) 0
1 \(\displaystyle \le\) i \(\displaystyle \le\) 4
Question 1 :
Explain why the writing of that linear programming in the form proposed above allows one iteration of the simplex algorithm
Question 2 :
Give the associated solution with P1 form above. You will yield the value of each variable and the objective function.
Question 3 :
Apply the simplex algorithm. You will give the value for each variable for the optimal solution after iteration.
Question 4 :
Compare results between question 2 and 3 solutions
Question 5 :
Infer from the previous question that the stopping criterion of the simplex algorithm is sufficient but not necessary condition.
Answer 1: The writing of the linear programming in the form proposed above allows one iteration of the simplex algorithm because it is expressed in the standard form. This means that all variables are greater than or equal to zero and that the objective function is a linear combination of the variables. The simplex algorithm can be applied to this form of linear programming, which is why it allows one iteration of the algorithm.Answer 2:The associated solution with P1 form above is x1 = 0, x2 = 1, x3 = 0, x4 = 1, and the objective function value is z = 2.Answer 3:Applying the simplex algorithm, the optimal solution after iteration is x1 = 0, x2 = 0, x3 = 1, x4 = 1 and the objective function value is z = 2.Answer 4:Comparing results between question 2 and 3 solutions, we see that the values for the variables are the same (x1 = 0, x2 = 0, x3 = 1, x4 = 1) but the objective function value is different (question 2: z = 2, question 3: z = 2). This is because the simplex algorithm optimizes the objective function value.Answer 5:Inferring from the previous question, we can conclude that the stopping criterion of the simplex algorithm is a sufficient but not necessary condition. This means that while the simplex algorithm will always find an optimal solution, it may not be the global optimal solution.
FAQ: Linear programming problem (simplex algorithm)
What is a linear programming problem?
A linear programming problem is a mathematical optimization technique used to find the maximum or minimum value of a linear objective function, subject to a set of linear constraints. It involves identifying the best possible solution from a set of feasible solutions.
What is the simplex algorithm?
The simplex algorithm is a method used to solve linear programming problems. It is an iterative process that moves from one feasible solution to another along the edges of the feasible region until the optimal solution is reached. It is based on the concept of duality, where the optimal solution of the dual problem is used to obtain the optimal solution of the original problem.
What are the steps involved in solving a linear programming problem using the simplex algorithm?
The steps involved in solving a linear programming problem using the simplex algorithm are:
  1. Formulate the linear programming problem by defining the objective function and the constraints.
  2. Convert the problem into standard form by introducing slack variables and writing all the constraints in the form of equations.
  3. Create the initial simplex tableau by writing the coefficients of the decision variables, slack variables, and the objective function in a matrix form.
  4. Apply the simplex algorithm to move from one feasible solution to another until the optimal solution is reached.
  5. Interpret the final simplex tableau to obtain the optimal solution and the optimal value of the objective function.
What are the assumptions of the simplex algorithm?
The assumptions of the simplex algorithm are:
  • The objective function and constraints are linear.
  • All variables are continuous and can take any real value.
  • The feasible region is convex.
  • The problem has a finite number of feasible solutions.
  • The objective function is either to be maximized or minimized.
What are the limitations of the simplex algorithm?
Some of the limitations of the simplex algorithm are:
  • It may not converge if the problem has an unbounded feasible region or an infeasible solution.
  • It may take a large number of iterations to reach the optimal solution, especially for large problems.
  • It is not suitable for problems with a large number of decision variables and constraints.
  • It cannot handle non-linear objective functions or constraints.
