MHB Linear Programming using the simplex method
Southwestern Oil is distributing oil to two distributors, S1 and S2, with specific minimum requirements and shipping costs. Distributor D1 requires at least 3000 barrels, while D2 needs at least 5000 barrels, with each outlet able to supply 5000 barrels. The total shipping cost must not exceed $40,000, factoring in both shipping costs and taxes. The objective function for minimizing costs has been established, and further constraints need to be defined to complete the linear programming model. Assistance is requested to finalize the constraints for an effective solution.
arl2267
Southwestern Oil supplies two distributors in the Northwest from two outlets. S1 and S2. Distributor S1 needs at least 3000 barrels of oil, and D2 needs at least 5000 barrels. The two outlets can each furnish exactly 5000 barrels of oil. The cost per barrel to ship the oil are:S1: D1=$30, D2=$20
S2: D1=$25, D2=$22There is also a shipping tax per barrel:S1: D1=$2, D2=$6
S2: D1=$5, D2=$4Southwestern Oil is determined to spend no more than $40,000 on shipping tax.a) How should the oil be supplied to minimize cost?
b) Find and interpret the values of any nonzero slack or surplus variableOkay so my attempt at coming up with the constraints is this:
Minimum: W=
30x1+20x2>=3000
25x3+22x4>=5000
x1+x2=50,000I think what is throwing me off is the shipping tax. I understand that the forum rules are that we need to make an attempt, but I am having such a hard time with this, and would really appreciate some help.
Mathematics news on Phys.org
arl2267 said:
Southwestern Oil supplies two distributors in the Northwest from two outlets. S1 and S2. Distributor D1 needs at least 3000 barrels of oil, and D2 needs at least 5000 barrels. The two outlets can each furnish exactly 5000 barrels of oil. The cost per barrel to ship the oil are:S1: D1=$30, D2=$20
Minimum: W=
30x1+20x2>=3000
25x3+22x4>=5000
Hi arl2267, :)
Welcome to Math Help Boards! :)
First define your variables as,
\(x_{ij}\) - The number for barrels supplied from \(S_{i}\) to distributor \(D_{j}\) where \(i,j=1,2\)
So the total cost will be, \(z=(30+2)x_{11}+(20+6)x_{12}+(25+5)x_{21}+(22+4)x_{22}\). Hence the objective function is,
\[\mbox{Min }z=32x_{11}+26x_{12}+30x_{21}+26x_{22}\]
Since \(D1\) needs at least \(3000\) barrels of oil we have,
\[x_{11}+x_{21}\geq 3000\]
Can you try to obtain the rest of the constraints? :)
Kind Regards,
Sudharaka.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
