- 7,120
- 10,772
Hi All,
This is probably trivial. What is the difference between techniques such as Linear/Logistic Regression, others done in ML , when they are done in Standard software packages : Excel ( incl. add-ons ), SPSS, etc? Why use ML algorithms when the same can be accomplished with standard software without the need to write code? EDIT: I assume the ML part comes out to optimizing k through different partitions of the data set into training/test data , computing , in each case the FPs and FNs, for each choice of k computing the error or ROC curves?
