sphyics
- 102
What would be the linear speed of body in Antartica standing on a south pole.
sphyics said:What would be the linear speed of body in Antartica standing on a south pole.
Taftarat said:depends on reference point. earth? sun? solar system? galaxie?
sphyics said:consider Earth as reference point.
jarednjames said:Linear speed implies you are moving in a straight line. You are not.
You would be moving with rotational velocity (whether in reference to the Earth or Sun).
Of course this is largely semantics.
With the Earth as your reference point, you would be rotating on the spot but that is all. Like a ballerina in a music box.
sphyics said:yes i agree, hence i had an intuition, the answer as 360 degrees per day from the options given A) 7x10-5rad/s; B)360 degrees per day c)Both (A) &(B) D) 0
but I'm trying to put it mathematically :)
approximately ... its 7.2x10^-5rad/s {sorry for that i made a calculation error earlier.}jarednjames said:Well work out how many degrees are per second (360 / (24*60*60)).
Then convert that value to rad/s, see if it matches A.
jarednjames said:Problem is, that gives you a rotational speed, not strictly a linear one (bit of ambiguity in the question for my liking). So I'd say the answer is D.
what will be the change in momentum if a particle moves from one point to its diametrically opposite.
jarednjames said:Please note the difference between an objects linear velocity and angular velocity:
http://www.algebralab.org/lessons/lesson.aspx?file=trigonometry_triganglinvelocity.xml
Your whole body (and the Earth) will have one angular velocity (which comes from 360 degrees per day).
But each point on the Earths surface at a different radius will have its own linear velocity.
On the south pole, your left arm will have a higher linear velocity than your head.
At a point infinitely small, directly on the south pole you would have zero linear velocity.
So my point is that unless you know which part of your body they are referring to, you can't give a linear velocity. Only an angular one.
sphyics said:Consider a particle not a body, suppose if the particle was at equator T(Period)=24hrs, then v=r(radius vector)*w(angular velocity)
how to proced with a particle at poles...
jarednjames said:The only difference is the radius, and like I said, unless you know the specific part of the body (the radius) then you can't give an answer.
sphyics said:its a question from a competitive exam :)
The linear speed at South Pole Antarctica refers to the rate of change of an object's position as it moves along a straight path. It is typically measured in meters per second (m/s) or kilometers per hour (km/h).
Yes, linear speed at the South Pole is affected by its unique location on the Earth's axis. Due to the Earth's rotation, objects at the South Pole have a slower linear speed compared to those at other latitudes.
The main factor that affects linear speed at the South Pole is the Earth's rotation. Other factors that can influence linear speed include the rotation of the Earth's core and the elevation of the South Pole above sea level.
Linear speed at the South Pole is typically measured using specialized instruments such as GPS devices or radar systems. These instruments can accurately calculate an object's speed based on its position and the time it takes to travel a certain distance.
Studying linear speed at the South Pole is important for various scientific fields such as geology, meteorology, and climate science. It can also help us better understand the Earth's rotation and its effects on our planet's physical processes.
