Linear System-Coset: Solve Exercise & Learn
  • MHB
  • Thread starter mathmari
  • Tags
    Linear
In summary: I'm not sure what to think about this, but it's something like this:every solution is a linear combination of the coefficients of the equations.In summary, what you have to do is find all the solutions of the system of linear equations and calculate their linear combinations.
mathmari
MHB
5,049
Hi! I am stuck at an exercise.
I am asked to describe the set of solutions of a linear system as a coset of an appropriate subspace.
Could you explain me what I have to do?
You must already know that any system of linear equations can be expressed in the matrix form $Ax=B$, where $A$ is an $m\times n$ matrix, $B$ is an $n\times 1$ column vector and $x$ is the unknown. We need to find all such $x$ which satisfy $Ax=B$. Assume that the entries of $A$ and $B$ come from a field $F$ (which might be $\mathbb R$ or $\mathbb C$ most likely).
Let $x_0$ be a solution to $Ax=B$. Let $S$ be the set of all the vectors $y$ which satisfy $Ay=0$, that is, $S=\{y:Ay=0\}$. Show that $S$ is a subspace of the vector space $F^n$. Note that $x_0+S$ is a coset of $S$ all of whose elements are solutions of $Ax=B$. Can there be any other solutions?
So knowing a solution of the system, [tex] x_{0} [/tex], I have to say that the set of solutions as a coset of an subspace is [tex] x_{0}+S [/tex] ?
Note that $x_0+S=\{x_0+z:z\in S\}$. Yes, if $x_0$ is a solution then $x_0+S$ is the set of all the solutions. Can you prove this?
We know that [tex] Ax_{0}=B [/tex] and [tex] Az=0 [/tex], [tex] z \epsilon S [/tex] .
We want to prove that [tex] x_{0}+S [/tex] is the set of all the solutions, so
[tex] A(x_{0}+z)=Ax_{0}+Az=B+0=B [/tex].
Is that right??
Is that right??
Not entirely.
What you have proved is that each member of $x_0+S$ is a solution of $Ax=B$. But you have not shown that every solution of $Ax=B$ lies in $x_0+S$. Try it.
I'm stuck right now...I don't know how to prove this... Could you give me a hint?? :eek:
Is it maybe like that:
Let [tex]y_{0} [/tex] be another solution of the system , [tex] Ay_{0}=B [/tex] , then [tex] A(x_{0}-y_{0})=0 [/tex] and [tex] x_{0}-y_{0}=z [/tex] is a solution of [tex] Ax=0 [/tex]. So, [tex] y_{0}=x_{0}+z [/tex] .That means that every solution of [tex] Ax=B [/tex] lies in [tex] x_{0}+S [/tex] ?
Perfect! See why I wasn't giving away the solution?
Great! Thank you very much! :D
(Yes)
To clarify something:
When I have to describe the set of the solutions as a conset of the solutions, it's [tex] x_{0}+S [/tex]?
Umm.. I don't know what you mean by that. The set of all the solutions as a coset of a subspace is $x_0+S$ (symbols have meanings borrowed from previous posts.) 'Coset of solutions' is not making sense to me.
P.S. Please be more descriptive with your doubts.
The set of all the solutions is described as a coset of the subspace S?
Yes. $x_0+S$ is a coset of $S$.
- - - Updated - - -
Replace 'as' with 'is'. Was a typo. Sorry.
Ok! Thank you! :D
There is something very deep going on, here.
We are used to thinking of a system of linear equations such as:
\(\displaystyle Ax = b\)
as "something we solve for \(\displaystyle x\)" given the matrix \(\displaystyle A\) of coefficients, and the constant vector \(\displaystyle b\).
In this vein, what you have just shown is sometimes expressed as:
"general solution = particular solution + homogeneous solution".
Here, the solution set of the homogeneous system \(\displaystyle Ax = 0\) is the space \(\displaystyle S\), and \(\displaystyle x_0\) is some "particular" vector for which \(\displaystyle Ax_0 = b\).
But we can look at this another way: given m equations in n unknowns, we can think of the associated matrix of coefficients \(\displaystyle A\) as something that takes an n-vector as input, and gives an m-vector as output. In other words, a linear transformation (since matrices are linear transformations...in some sense the linear transformations).
The set of n-vectors \(\displaystyle x\) that \(\displaystyle A\) "kills" (maps to the 0 m-vector), the space \(\displaystyle S\), is the null space or kernel of \(\displaystyle A\).
If the system \(\displaystyle Ax = b\) HAS a solution, this means that \(\displaystyle b\) lies in the image (or range​) of \(\displaystyle A\). In fact, we can say something stronger:
There is a 1-1 correspondence between the elements \(\displaystyle b\) in the image of \(\displaystyle A\), and the distinct cosets \(\displaystyle x_0 + S\). We can use the vector space structure of the image to induce a vector space structure on the cosets. The precise statement of this is known as the Rank-Nullity theorem:
For a linear transformation \(\displaystyle A\):
\(\displaystyle \text{dim}(\text{dom}(A)) = \text{dim}(\text{im}(A)) + \text{dim}(\text{ker}(A))\)
In other words the range of A is isomorphic (as a vector space), to the quotient space \(\displaystyle \text{dom}(A)/\text{ker}(A)\).
If we call the domain of \(\displaystyle A,\ V\), and the kernel of \(\displaystyle A,\ S\), we can express this more succinctly as:
\(\displaystyle A(V) \cong V/S\).
This says the the space of POSSIBLE solutions to \(\displaystyle Ax = b\), acts very much like \(\displaystyle V\) (our space of n-vectors) except "shrunk down" by a factor of \(\displaystyle \text{dim}(S)\) (since \(\displaystyle A\) kills every n-vector in \(\displaystyle S\)).
It turns out that the set of cosets \(\displaystyle V/S\) of the form \(\displaystyle x + S\), can be made into a vector space in a pretty "obvious" way:
\(\displaystyle (x_1 + S) + (x_2 + S) = (x_1 + x_2) + S\)
\(\displaystyle a(x_1 + S) = ax_1 + S\) (for a scalar \(\displaystyle a\), and vectors \(\displaystyle x_1,x_2 \in V\)).
And this space is "smaller" than what we started with, so can be easier to work with.
In more concrete terms, when one solves a system of linear equations by row-reduction (to find the rank, or the dimension of the range, of the system), the dimension "left-over" (the number of "free variables", or parameters) is precisely the size of the basis of the null space of the system (null space = associated homogeneous system).
A baby example:
Suppose we have the equation:
\(\displaystyle 2x + 3y = 4\).
The rank of this system is clearly 1. Since our domain is the Euclidean plane, our null space (of the matrix:
\(\displaystyle A = \begin{bmatrix}2&3 \end{bmatrix}\))
is the subspace of the euclidean plane:
\(\displaystyle L = \{(x,y) \in \Bbb R^2: 2x+3y = 0\}\)
perhaps more clearly recognizable as the line through the origin:
\(\displaystyle y = -\frac{2}{3}x\)
Thus the solution set of our system is the line in \(\displaystyle \Bbb R^2\) parallel to \(\displaystyle L\) passing through the point (2,0), that is the line:
\(\displaystyle y = -\frac{2}{3}x + 2\).
As noted above, there is a 1-1 correspondence between the lines parallel to \(\displaystyle L\) in the plane, and the real numbers, we can just send each coset (parallel line) to twice its y-intercept:
the line \(\displaystyle (x_0,0) + L\) is the solution set to:
\(\displaystyle 2x + 3y = 2x_0\), or in perhaps more familiar form, the solution space to:
\(\displaystyle 2x + 3y = b\) is:
\(\displaystyle \{(x,y) \in \Bbb R^2: (x,y) = \left(\frac{b-3t}{2},t \right) = \left(\frac{b}{2},0 \right) + t\left(-\frac{3}{2},1 \right), t \in \Bbb R\} = \left(\frac{b}{2},0\right) + L\)
(as one can see here, the vector (-3/2,1) forms a basis for the null space \(\displaystyle L\)).
"Chop the plane into parallel lines, and what you get 'acts like a line' (you can use a line crossing all the parallel lines to determine WHICH parallel line you're at)".
Nice! Thank you very much! :D
FAQ: Linear System-Coset: Solve Exercise & Learn
What is a linear system-coset?
A linear system-coset is a mathematical concept used to solve systems of linear equations. It involves finding a particular solution to the system and then adding a coset, which is a set of solutions that are equivalent to the particular solution.
How do you solve a linear system-coset?
To solve a linear system-coset, you first need to find a particular solution to the system of linear equations. Then, you add a coset, which is a set of solutions that are equivalent to the particular solution. This creates a set of solutions for the system.
What is the purpose of solving exercises related to linear system-coset?
The purpose of solving exercises related to linear system-coset is to gain a better understanding of the concept and to practice applying it to different problems. It also helps to develop problem-solving skills and improve mathematical reasoning.
How can I learn more about linear system-coset?
There are many resources available for learning more about linear system-coset, including textbooks, online tutorials, and instructional videos. You can also consult with a math teacher or tutor for additional guidance and support.
What are some real-world applications of linear system-coset?
Linear system-coset has many applications in fields such as engineering, physics, and economics. It can be used to model and solve problems related to electrical circuits, chemical reactions, and optimization of resources.
