Linear transformation across a line
In summary, using linear transformation reflection, we can find the standard matrix of the composition of two reflections. In this case, the composition is a counterclockwise rotation about the origin by an angle of -455/697 radians.
1up20x6
Using linear transformation reflection to find rotation
Let [itex]T1[/itex] be the reflection about the line [itex]−4x−1y=0[/itex] and [itex]T2[/itex] be the reflection about the line [itex]4x−5y=0[/itex] in the euclidean plane.
The standard matrix of [itex]T1 \circ T2[/itex] is what?
Thus [itex]T1 \circ T2[/itex] is a counterclockwise rotation about the origin by an angle of how many radians?
[itex]\frac{1}{1+m^2}\begin{pmatrix}
1-m^2 & 2m\\
2m & m^2-1
\end{pmatrix}[/itex]
I've used the relevant equation above and found that [itex]T1 \circ T2 = \begin{pmatrix}
\frac{-455}{697} & \frac{-528}{697}\\
\frac{-455}{697} & \frac{-455}{697}\end{pmatrix}[/itex] and had this verified, but I have no idea how to relate this into an amount of radians rotated.
hi 1up20x6! :smile:
should be [itex]\begin{pmatrix}
\cos & \sin\\
-\sin & \cos\end{pmatrix}[/itex] :wink:
FAQ: Linear transformation across a line
What is a linear transformation?
A linear transformation is a function that maps one vector space to another while preserving the basic structure of the space. In other words, it transforms a set of vectors in one space to a set of vectors in another space in a linear manner.
What is a line of transformation?
A line of transformation is a straight line that is used to visualize a linear transformation. It represents the path of a vector as it is transformed by the linear function.
How does a linear transformation across a line work?
A linear transformation across a line works by taking each point on the line and transforming it according to the given linear function. The resulting points create a new line that is the image of the original line.
What is the difference between a linear transformation and a nonlinear transformation?
A linear transformation preserves the basic structure of the vector space, while a nonlinear transformation does not. This means that a linear transformation will always result in a straight line, while a nonlinear transformation can result in a curved line or shape.
What is the importance of linear transformations in mathematics and science?
Linear transformations are important in mathematics and science because they can be used to represent and solve many real-world problems. They also have applications in fields such as computer graphics, physics, and economics.
