srfriggen
- 307
- 6
(note; all column vectors will be represented as transposed row vectors, and matrices will be look like that on a Ti-83 or similar)
L: R^3 -> R^2 is given by,
L([x1, x2, x3]) = [2x1 + x2 - x3
x1 + 3x2 +2x3]*
*Matrix
Relevant Equations:
2x1 + x2 - x3 = b1 (a)
x1 + 3x2 + 2x3 = b2 (b)
Determine whether L is one-to-one
I set L(x) = b for a particular vector b = [b1, b2] in R^2 and solved for the x's in terms of b1 and b2.
after using rref I find x1 and x2 are the leading variables, and x3 is arbitrary, which I call r. Solving the equations leads to;
x1 = r + (1/5)(3b1 - b2)
x2 = -r + (1/5)(2b2 - b1)
Since the nonleading variable x3 = r is arbitrary, there are infinitely many solutions for x for a particular b. thus, L is not one-to-one.
My question is, what is happening geometrically in this problem?
Could this be represented as (1) two planes intersecting for form a line, where the line is the solution set?
(2) A plane lying on top of a plane? (I don't think this is true for if it were I could choose any x1 x2 and x3 and would get the same solution in the equations (a) and (b)... right?
(3) A plane in R^3 intersecting the plane that makes up the subspace R^2 but not going "through" the subspace... just touching it to form a line.
(4) A plane in R^3 intersecting the R^2 plane and passing through it (is that possible)?
I suspect either (3) or (4) is happening.
Any insight would be greatly appreciated.
