Linear transformation one-to-one
In summary, a linear transformation one-to-one is a function between two vector spaces that preserves the algebraic operations and maps each element of the domain to a different element in the range. To determine if a linear transformation is one-to-one, we can use the nullity-rank theorem. This theorem states that the nullity and rank of the linear transformation must be equal. One-to-one linear transformations differ from onto linear transformations in that onto transformations map every element in the range to at least one element in the domain. A linear transformation can be both one-to-one and onto, which is known as an isomorphism. Real-life examples of one-to-one linear transformations include scaling and rotation transformations, unit conversions, and encryption and decryption functions.
jonroberts74
189
let ##T:\mathbb{R^3} \rightarrow \mathbb{R^3}## where ##T<x,y,z>=<x-2z,y+z,x+2y>##
Is T one-to-one and is the range of T ##\mathbb{R^3}##?
I took the standard matrix A ##\left[\begin{array}{cc}1&0&-2\\0&1&1\\1&2&0\end{array}\right]##
det(A)=0 so by equivalence T is not one-to-one and by equivlence again the range is not ##\mathbb{R^3}##
What is your question?
is that correct?
I suspect you already know the answer is yes.
FAQ: Linear transformation one-to-one
What is a linear transformation one-to-one?
A linear transformation one-to-one is a function between two vector spaces that preserves the algebraic operations of addition and scalar multiplication. This means that for every input, there is a unique output, and no two inputs will result in the same output. In other words, the function maps each element of the domain to a different element in the range.
How can we determine if a linear transformation is one-to-one?
To determine if a linear transformation is one-to-one, we can use the nullity-rank theorem. This theorem states that the nullity of a linear transformation is equal to the dimension of the null space, and the rank of the linear transformation is equal to the dimension of the range. If the nullity and rank are equal, then the linear transformation is one-to-one.
What is the difference between one-to-one and onto linear transformations?
A one-to-one linear transformation maps each element of the domain to a different element in the range, while an onto linear transformation maps every element in the range to at least one element in the domain. In other words, a one-to-one linear transformation has a unique output for each input, while an onto linear transformation has a full range of outputs.
Can a linear transformation be both one-to-one and onto?
Yes, a linear transformation can be both one-to-one and onto. This type of linear transformation is called an isomorphism, which means it preserves both the algebraic operations and the structure of the vector spaces. In other words, an isomorphism is a bijective linear transformation.
What are some real-life examples of one-to-one linear transformations?
Some real-life examples of one-to-one linear transformations include scaling and rotation transformations in geometry, conversion between different units of measurement, and encryption and decryption functions in computer science. In each of these examples, there is a unique output for every input, and no two inputs will result in the same output.
