Linear Vector function of a vector
In summary, the conversation discusses whether a given function is a linear vector function of a given vector. Two equations are presented and the concept of a linear function is defined. The speaker eventually understands the concept and also mentions knowing the formula for the vector triple product.
Winzer
598
For each state wheather the function is a linear vector function of [tex] \vec{v} [/tex]
1.[tex] \vec{F}(\vec{v})=\alpha \vec{v} [/tex]
2. [tex] \vec{F}(\vec{v})= \vec{a} \times (\vec{b} \times \vec{v}) + (\vec{a} \times \vec{v}) \times \vec{v}[/tex]
I don't get what they mean. The book makes it look ambigious.
They make what look ambiguous? The definition of a linear function? A linear function is a function f such that
[tex]f(\vec{x}+\vec{y})=f(\vec{x})+f(\vec{y})[/tex]
[tex]f(a\vec{x})=af(\vec{x}).[/tex]​
Edit: Or, are you not sure what they mean by F being a function of v?
B.T.W., do you know the formula for the vector triple product?
Actually I get it, it was presented differently in the book. It's all so trivial now. And yes I do know the formula for a triple product
great!
Related to Linear Vector function of a vector
1. What is a linear vector function?
A linear vector function is a mathematical function that maps a vector input to a vector output. It follows the properties of linearity, meaning that the function preserves vector addition and scalar multiplication.
2. How is a linear vector function represented?
A linear vector function is typically represented using matrix notation, where the input vector is multiplied by a transformation matrix to produce the output vector. It can also be represented using a system of linear equations.
3. What is the difference between a linear and non-linear vector function?
A linear vector function preserves the properties of linearity, while a non-linear vector function does not. This means that a linear vector function will always produce a straight line or plane when graphed, while a non-linear vector function can produce curved or non-planar shapes.
4. Can a linear vector function have more than one input?
Yes, a linear vector function can have multiple inputs, but it must also have multiple outputs in order to preserve linearity. This would typically be represented using a vector of inputs and a vector of outputs, and a transformation matrix that maps between them.
5. What are some real-world applications of linear vector functions?
Linear vector functions have many applications in fields such as physics, engineering, and computer graphics. They are used in systems of equations to model linear relationships between variables, in transformations to manipulate and analyze data, and in computer graphics to create 3D objects and animations.
