Linearising Christoffel symbols
In summary, "Linearising Christoffel symbols" involves simplifying the Christoffel symbols, which represent how coordinates change in curved spacetime, to a linear approximation suitable for small perturbations. This process aids in understanding the behavior of geodesics and the influence of curvature in general relativity. By approximating the symbols around a flat background, one can derive essential equations governing motion in a gravitational field, facilitating analysis in theoretical physics and cosmology.
chartery
40
Carroll linearising by perturbation ##g_{\mu\nu}=\eta_{\mu\nu}+h_{\mu\nu}## has: (Notes 6.4, Book 7.4)
##\Gamma^{\rho}_{\mu\nu}=\frac{1}{2}g^{\rho\lambda}\left( {\partial_{ \mu}}g_{\nu\lambda}+{\partial_{ \nu}}g_{\lambda\mu}-{\partial_{ \lambda}}g_{\mu\nu}\right)=\frac{1}{2}\eta^{\rho\lambda}\left( {\partial_{ \mu}}h_{\nu\lambda}+{\partial_{ \nu}}h_{\lambda\mu}-{\partial_{ \lambda}}h_{\mu\nu}\right)##
This must mean that ##{\partial_{ \mu}}h_{\nu\lambda}## is taken to be of same order as ##h^{\rho\lambda}##
I can't find a justification anywhere, so I guess everyone thinks it self-evident.
Is it certain that a weak gravitational field cannot vary quickly or 'strongly' ?
It is essentially the matrix equivalent of
\frac{1}{1+x} \simeq 1 - x
for small ##x##
for small ##x##
Sorry, you've lost me. Were you referring to ##g^{\mu\nu}=\eta^{\mu\nu}-h^{\mu\nu}##?
My problem was how to know that the partial derivative (i.e. variation) of a small item was necessarily also small.
if ##\frac{1}{1+x}## is how I should think of ##\partial_{\mu}## here, I'm afraid I need extra guidance.
It becomes more clear if you write
$$g_{\mu \nu}=\eta_{\mu \nu} + \epsilon h_{\mu \nu} \qquad (1)$$
with ##\epsilon=const.## and taking all quantities of interest only up to linear order in ##\epsilon##.
For the inverse metric you have
$$g^{\mu \nu}= \eta^{\mu \nu} -\epsilon h^{\mu \nu}+\mathcal{O}(\epsilon^2)$$
with
$$h^{\mu \nu}=\eta^{\mu \rho} \eta^{\nu \sigma} h_{\rho \sigma}, \qquad (2)$$
because then
$$(\eta^{\mu \nu} - \epsilon h^{\mu \nu}+\mathcal{O}(\epsilon^2))(\eta_{\nu \sigma} + \epsilon h_{\nu \sigma}= \delta_{\sigma}^{\mu} - \epsilon {h^{\mu}}_{\sigma}) + \epsilon {h^{\mu}}_{\sigma}+\mathcal{O}(\epsilon^2) = \delta_{\sigma}^{\mu} + \mathcal{O}(\epsilon^2).$$
For the Christoffels you plug (1) and (2) in the definition equation and immediately see that they are of order ##\epsilon## and given at this order by the equation in the OP.
Likes dextercioby and chartery
I may have read your OP a bit quick. There are a couple of things to consider here.
The foremost one is that the derivatives of eta vanish and the derivatives you have left are multiplied by essentially eta+O(h). Regardless of the derivatives of h are in terms of size, multiplying them by h is going to give you something of higher order than multiplying by eta.
Apart from that, further assumptions on slow variations etc are common.
Likes chartery
Sorry @vanhees71 I can't get the multiple quote insert to work!Yes, my problem was being sure that ##h^{\rho\lambda}{\partial_{ \mu}}h_{\nu\lambda}## terms were order ##h^2##
It makes sense that ##\epsilon h^{\rho\lambda} {\partial_{ \mu}}\epsilon h_{\nu\lambda}## would be order ##\epsilon^2##
Many thanks
Many thanks
I mean, your worry is partially justified. There is nothing a priori stopping ##\partial h## to be order ##1/\epsilon## in the above. However, it will always be the case that - regardless of the order of the derivative - the h-term in front will be one order higher than the leading one.
Likes vanhees71
Sorry for gap. I can see Vanhees understands, though it seems to me if ##\partial h## is order ##1/\epsilon## then ##\epsilon h^{\rho\lambda} {\partial_{ \mu}}\epsilon h_{\nu\lambda}## is only order ##\epsilon## but needs to be order ##\epsilon^2## to be ignored in OP equation?
If that is the case then the leading term in OP's equations is ##\mathcal O(1)##, not ##\mathcal O(\epsilon)##. Therefore, to leading non-trivial order, terms ##\mathcal O(\epsilon)## should be ignored.
Likes chartery and vanhees71
Durr... Got fixated on second term of ## \eta^{\rho\lambda} {\partial_{ \mu}}\epsilon h_{\nu\lambda} - \epsilon h^{\rho\lambda} {\partial_{ \mu}}\epsilon h_{\nu\lambda}## (just in case someone of similar density looking up).
Many thanks.
FAQ: Linearising Christoffel symbols
What are Christoffel symbols?
Christoffel symbols, denoted typically by Γ, are mathematical objects used in differential geometry to describe the connection coefficients of a Levi-Civita connection. They play a central role in the equations of general relativity, helping to define how vectors change as they are parallel transported around a curved space or spacetime.
Why is linearising Christoffel symbols important?
Linearising Christoffel symbols is important because it simplifies the equations of general relativity in weak gravitational fields. By approximating the symbols to their first-order terms, one can more easily solve problems related to gravitational waves, weak-field approximations, and perturbation theory.
How do you linearise Christoffel symbols?
To linearise Christoffel symbols, one typically expands the metric tensor \( g_{\mu\nu} \) around a flat spacetime metric \( \eta_{\mu\nu} \) such that \( g_{\mu\nu} = \eta_{\mu\nu} + h_{\mu\nu} \), where \( h_{\mu\nu} \) represents a small perturbation. The Christoffel symbols are then expanded to first order in \( h_{\mu\nu} \), simplifying the expressions significantly.
What is the physical significance of linearised Christoffel symbols?
The physical significance of linearised Christoffel symbols lies in their ability to describe the behavior of gravitational fields in the weak-field limit. This approximation is crucial for understanding phenomena such as gravitational waves, small perturbations in spacetime, and the motion of objects under weak gravitational influences.
Can you provide an example of linearising a Christoffel symbol?
An example of linearising a Christoffel symbol starts with the full expression for the Christoffel symbol in terms of the metric tensor: \( \Gamma^\lambda_{\mu\nu} = \frac{1}{2} g^{\lambda\sigma} (\partial_\mu g_{\nu\sigma} + \partial_\nu g_{\mu\sigma} - \partial_\sigma g_{\mu\nu}) \). By substituting \( g_{\mu\nu} = \eta_{\mu\nu} + h_{\mu\nu} \) and keeping only the linear terms in \( h_{\mu\nu} \), the expression simplifies to \( \Gamma^\lambda_{\mu\nu} \approx \frac{1}{2} \eta^{\lambda\sigma} (\partial_\mu h_{\nu\sigma} + \partial_\nu h_{\mu\sigma} - \partial_\sigma h_{\mu\nu}) \).
