Linux - Moving/Copying Files via terminal
In summary, the conversation is discussing the process of moving files and folders from one directory to another. The suggested solution is to use the command `cp mv -vr \Downloads\* .` but the speaker is unsure if it is correct and whether the `-v` argument is necessary. They also mention that the files being copied have the same names but different content. The conversation then shifts to discussing the `mv` command and a tutorial is shared. The final conclusion is that the correct command for moving `dir1` to `dir2` is `mv dir1 dir2`.
Arman777
Insights Author
193
I am trying to move files and folders from one directory to other. Both of the files has multiple subfolders and files.
From the reasearch I have made it seems that the answer should be something like,
But I am not sure this is true or not. I am also not sure about using mv or copy. The files that I am copying have the same file names but the content is different.
Is this command correct ? Do I need '-v` argument ?
Technology news on Phys.org
Yes sorry it’s that darn spellcheck acting up again. I’m in Yosemite with spotty internet and tried to fix it but lost the signal.
Thanks for the help..
Likes berkeman and jedishrfu
FAQ: Linux - Moving/Copying Files via terminal
How do I move a file from one location to another using the terminal?
To move a file from one location to another using the terminal, you can use the "mv" command. The syntax is "mv [file name] [destination]." For example, if you want to move a file named "file1.txt" to a folder named "documents", you would use the command "mv file1.txt documents". This will move the file to the specified destination.
Can I move multiple files at once using the terminal?
Yes, you can move multiple files at once using the "mv" command. Simply list all the files you want to move after the destination. For example, if you want to move "file1.txt", "file2.txt", and "file3.txt" to a folder named "documents", the command would be "mv file1.txt file2.txt file3.txt documents".
How do I copy a file to a different directory using the terminal?
To copy a file to a different directory using the terminal, you can use the "cp" command. The syntax is "cp [file name] [destination]." For example, if you want to copy a file named "file1.txt" to a folder named "documents", you would use the command "cp file1.txt documents". This will create a copy of the file in the specified destination.
Can I copy a directory and its contents using the terminal?
Yes, you can copy a directory and its contents using the "cp" command. Simply add the "-r" option to the command, which stands for "recursive". This will copy the directory and all its subdirectories and files. For example, if you want to copy a folder named "pictures" and all its contents to a folder named "backup", the command would be "cp -r pictures backup".
How do I rename a file using the terminal?
To rename a file using the terminal, you can use the "mv" command. The syntax is "mv [current file name] [new file name]." For example, if you want to rename a file named "oldname.txt" to "newname.txt", the command would be "mv oldname.txt newname.txt". This will rename the file to the specified new name.
