Liquid nitrogen generator, N2 gas generator
In summary, this person has written extensive tutorials on the theory and building of a homemade N2 gas generator. They use pressure swing adsorption to concentrate N2 up to 99%. The inversion temperature for N2 and O2 is well above room temperature, so this generator could liquefy any gases except helium. They also created a cryogenic thermometer which could be useful for experiments.
imsmooth
155
I thought some of you engineers would be interested in reading my web tutorials. I have written some extensive tutorials on the theory and building of a homemade N2 gas generator. It takes regular air, and using pressure swing adsorption, concentrates the N2 up to 99%. This is here.
I then use this to supply the N2 for my homemade liquid nitrogen generator. I can liquefy N2 in my garage without any fancy, high-tech equipment. This tutorial is here.
What I'd really like to do is fabricate a small turbo expander, but I think I would need a CNC to do it correctly. Anyway, my generator produces about 300-350 cc/hr of LN2.
Likes rppearso
Impressive! Wish I was as good with lathes & stuff.
How do you get it below the JT Inversion Temp. the very first time? When you've no LN2 to cool the gas against?
The inversion temperature for N2 and O2 is well above room temperature unlike Helium. I would love to make a turbo expander if anyone has some useful information or references.
Ah. So you could liquify any gases except those two I guess.
Industrial turbo expanders are intricate & carefully designed, but for a home brew I wonder if a piston like engine would work?
Essentially you want to take out work, somehow?
This is a really interesting project. Congratulations on your success.
It would be impractical for me to attempt this at the moment but it is definitely going on my list of projects to attempt in the future. For now I will limit myself to the theory.
That compressor is a beast. The temperature change appears to be linear with respect to the pressure drop so I wonder whether a higher volume flow rate at lower pressure would also work. If the mass flow rate is kept constant could the pressure be reduced?
I'm not sure how that would alter the efficiency of the heat exchanger.
How much ice does it consume?
p.s. While reading through your tutorial I noticed that you sometimes switch between units while the values remain the same. For example on http://homemadeliquidnitrogen.com/ you talk about a 1/4 degree Fahrenheit temperature drop for each atmosphere of pressure drop. However, on http://homemadeliquidnitrogen.com/compressor.html this becomes a 0.25C temperature drop.
If AHS wasn't covering my oxygen generators, I'd be actively seeking you out right now. The portable unit cost over $5,000. It's exactly the same as your machine in principle, except it spits the nitrogen out and releases the remainder (98+% oxygen) into my nose. Top speed is 3 litres/minute on constant flow or up to 6L/m on pulse (demand regulator). The plug-in home unit is constant only and goes up to 10.
I'm glad you all find this interesting. This took a lot of research and work. Figuring out the baffle section was also trial and error, and some consultation with an engineer at Air Products. I fixed the 1/4 F / 1/4 C typo. I believe it is 1/4 C all around. I am sure a lower pressure with a higher mass flow rate will work. One just has to make sure more heat leaves the system than seeps back into it. If I was running experiments for a mass-marketed product I would a high-flow rate compressor running at a few hundred psi. I am guessing that if you don't have really high flows the gradient will be too low, and you will have a very, very long cool-down.
The unit consumes almost no ice. The ice-bath takes some of the heat out. A lot of heat comes out on the compressor-side when the coils get cooled by a fan.
If anyone is interested, I built a highly accurate cryogenic thermometer for this stuff. It is accurate to tenths of a degree (F and C). You can see it at http://homemadeliquidnitrogen.com/crybaby.
Maybe some of you can use it for your experiments.
Related to Liquid nitrogen generator, N2 gas generator
What is a liquid nitrogen generator?
A liquid nitrogen generator is a device that produces liquid nitrogen by compressing and cooling air to extremely low temperatures, typically below -320°F. This allows for the separation of nitrogen gas from other components in the air, resulting in a pure liquid nitrogen output.
How does a liquid nitrogen generator work?
A liquid nitrogen generator works by using a series of compressors and heat exchangers to compress and cool air. The compressed air is then fed into a separation unit, where it is cooled further until it reaches its boiling point and turns into a liquid. The liquid nitrogen is then collected and stored in a tank for use.
What are the benefits of using a liquid nitrogen generator?
Using a liquid nitrogen generator has several benefits, including cost-effectiveness, reliability, and safety. It eliminates the need for purchasing and storing liquid nitrogen, reduces the risk of potential hazards during transportation, and allows for on-site production, saving time and money.
What are the applications of a liquid nitrogen generator?
Liquid nitrogen generators are commonly used in industries such as food and beverage, medical, and pharmaceutical for cryopreservation, freezing, and cooling purposes. They are also used in scientific research, cryotherapy, and as a coolant in various industrial processes.
Are there any safety considerations when using a liquid nitrogen generator?
Yes, there are safety considerations when using a liquid nitrogen generator. Liquid nitrogen is extremely cold and can cause severe frostbite if it comes into direct contact with the skin. It is also important to ensure proper ventilation to prevent the build-up of nitrogen gas, which can displace oxygen and lead to asphyxiation. Proper training and caution should be exercised when handling and storing liquid nitrogen.
  • Thermodynamics
  • Aerospace Engineering
  • Mechanical Engineering
10K
