Liquid-solid phase composition: Binary phase diagrams
In summary: The reason is that when you put the salt in water, it dissolved to form a saturated solution. When you cool it, the solution became less saturated and the salt precipitated.
Biker
416
52
In binary phase diagram, We draw a tie line to know the composition of the liquid phase or the solid phase. Where the tie line is just a horizontal line.
The question is why doesn't the liquid or solid phase composition change as you change the general composition of the alloy? Why does the horizontal line give the liquid/solid composition for any general composition? Shouldn't the matter behave differently as you change the general composition?
Chemistry news on Phys.org
I am not sure I understand your question. Horizontal line is just a line of constant temperature. No matter what the composition is, you can heat the mixture to any temperature. Then, from the diagram, you can read what to expect - just a solid mixture, just a liquid mixture, or some combination of both.
My bad, Say you have a alloy made of 40% A and 60% B and another alloy 30% A and 70% B, if you heat both to the same temperature where you would have two phases ( Solid and liquid), Using tie line, You will find that the liquid or solid phase has the same composition regardless of the general composition of the alloy. Like shouldn't each alloy have a different cooling composition?
It might seem a dumb question but I don't really understand why the tie line would give the composition of the liquid or solid phase for any general composition at some temperature.
Example - alloy of ice and salt. The composition of liquid depends on the temperature and thus solubility of salt in water. Not on general composition of alloy - only the amount of solid and liquid varies.
Vertical line is where the mixture has a given composition (defined by the x coordinate). When there are two phases present they can have different compositions as long as their mixture has the correct ratio of both alloyed substances.
Say you have a jar of water solution of a salt that has solubility of 100 g of salt per 100 g of water at 100°C, but is almost insoluble at 0°C. You start with a 50/50 mixture at 100°C and you cool it down. Salt drops out from the solution and you have two phases - pure salt, and solution that has less and less dissolved salt. But the content of the jar is still the same 50/50.
Related to Liquid-solid phase composition: Binary phase diagrams
1. What is a binary phase diagram?
A binary phase diagram is a graphical representation of the relationship between temperature, pressure, and the composition of a mixture of two substances. It shows the different phases that exist at various combinations of temperature and pressure, and how the composition of the mixture affects the phases.
2. How is a binary phase diagram constructed?
A binary phase diagram is constructed by plotting the composition of the mixture on the x-axis and the temperature or pressure on the y-axis. The regions on the diagram represent the different phases that exist at that particular temperature and pressure. The lines on the diagram show the boundaries between the different phases.
3. What is the eutectic point in a binary phase diagram?
The eutectic point is the lowest temperature at which a liquid mixture can exist in equilibrium with its solid phases. It is the point where the liquid and solid phases have the same composition, and any further cooling will result in the formation of a different solid phase.
4. How do you read a binary phase diagram?
To read a binary phase diagram, you need to identify the composition of the mixture and its corresponding temperature or pressure on the axes. Then, find the point on the diagram where these two values intersect. This will determine the phase or phases that exist at that particular combination of temperature and composition.
5. What can a binary phase diagram tell us about a mixture?
A binary phase diagram can tell us about the stability of a mixture and the changes in its phases at different temperatures and pressures. It can also show the maximum and minimum temperatures at which a particular phase can exist. Additionally, it can help predict the behavior of a mixture during cooling or heating processes.
  • Materials and Chemical Engineering
