scienceboy2000
- 7
Little bit of help for science fair project please!
Hi guys, I am 13 years old and I am a new member on this forum and I need help with a science fair project.
For my project I am showing how companies make tablets so I need to learn how to make a tablet. I did some research but some of the details are confusing so I would appreciate your help!
This is what I have so far. I took some pieces of chalk and crushed them so that only powder is left because all tablets start off as powder. The process that I have to follow requires me to make the powder into a solid again. I asked my dad for some help and he made something for me called a pollen press. He said that I can put the powder inside of the pollen press and the press will make the powder into a solid. But I read on some websites that companies use an expensive type of press called a pill press (which basically does the same thing as a pollen press), but that there are other things you have to do first because otherwise the tablet is not strong enough and will crumble.
One of the things you have to do is add something called a binding agent into the powder to make the grains stick together, which will make the tablet more solid in the end. I read that for tablets you don't use a binding agent that is super strong (don't use one that you would use for concrete, for example). Some of the binding agents that they use are povidone, xanthan gum and carbopol. They also use something called a filler to just take up volume in the pill (to make it bigger). Sometimes the binding agent is also used as a filler.
My only problem is that I can't find any information on how to use a binding agent. So I just pour it in with the powdered chalk that I have? Do I make some type of solution? Do I add heat or anything like that? This is the main part where I am confused.
I would be very thankful for any help I can get. Thank you.
