Little Odd-ratio/ relative risk confusion
In summary, the author is asking if it is okay to compute the odds ratio (relative risk) of being undernourished with the reference group being boys instead of the other way around. The author suggests that the odds ratio (relative risk) is preferred.
BobbyBear
162
Hi, just a small doubt I'm having:
I'm given a cross tabulation table, such as undernourished status versus gender of the child:
-----------------------------undernourished
-----------------------------yes--------no
--------------------boy------37-------- 86
---------gender
--------------------girl-------40--------74suppose we are told to compute the relative risk of being undernourished with the reference group being boys,
I think we should compute: (40/(40+74)) / (38/(37+86))
and not the other way around, right?
Likewise, the odds ratio of being undernourished with the reference group being boys would be: (40/74) / (38/86) and not the other way around, I suppose?
I just want to make sure what "with the reference group being boys" means... I'm assuming it means it means odds of undernourished girls to odds of undernourished boys, but I'm not 100% sure if it means this or if it might mean we are interested in boys so it should be odds of boys to odds of girls?
thanks!
Suppose we are told to compute the relative risk of being undernourished with the reference group being boys,
thanks!
You could use either one as a comparison group, but it's often preferred to have a hypothesis about which group would be at lower risk as the comparison group before the data is collected an analyzed. In this case the girl's rate is 0.35 while the boy's rate is 0.30 resulting in a rate ratio of 1.17.
To test if this represents a statistically significant difference you could do a test comparison of two rates based on the normal distribution (Z score) if the normal assumption holds. The odds ratio is preferred by some. The ln[itex] (\psi) [/itex] (log odds) can be used in logistic regression. It is considered an estimate of the rate ratio and in this case it's 1.26. The rate ratio is of course exact but has less desirable mathematical properties.
Some points. You used 38 instead of 37 in your calculations of the boys rate so your answers would be slightly different than mine. In your table you usually will put your comparison group in the lower row. Then you can use the cross product ad/bc to calculate the odds ratio.
I don't like the term "relative risk". It's not a very meaningful description. I prefer rate ratio or odds ratio. It's not clear just what one is referring to with the term 'relative risk' although it is often used.
"with the reference group being boys" means that you are looking only at the boys, not the girls. And that means that you are wrong. There are 37 undernourished boys out of a total of 37+ 86= 123 boys. The probability of a boy being undernourished is 37/123.
thank you both for your comments!
... but if I am asked for an odds ratio, then I am not being asked for a ratio between girl undernourishment odds and boy undernourishment odds? Looking at boys alone, I can only have the odds of undernourishment in boys, not a ratio of odds... I think "with the reference group being boys" is simply stating that boys is the "comparison group", as SW VandeCarr put it, which means it is sort of the benchmark for any other group.
Does that make sense?
I can confirm that your understanding of computing relative risk and odds ratio is correct. When the reference group is specified as boys, it means that we are interested in comparing the risk or odds of being undernourished for girls to the risk or odds for boys. So, your calculation of (40/(40+74)) / (37/(37+86)) for relative risk and (40/74) / (37/86) for odds ratio is correct. It is important to specify the reference group in order to accurately interpret and compare the results.
Related to Little Odd-ratio/ relative risk confusion
What is the difference between odds ratio and relative risk?
The odds ratio and relative risk are two commonly used measures of association in epidemiological studies. The odds ratio is a measure of the strength of association between an exposure and an outcome, while the relative risk is a measure of the risk of developing the outcome given the exposure. The main difference between the two is that the odds ratio is calculated using the odds (a ratio of the number of events to the number of non-events), while the relative risk is calculated using the risk (the proportion of individuals who develop the outcome).
When should odds ratio be used over relative risk?
The odds ratio should be used when the outcome of interest is rare, i.e. when the risk is less than 10%. This is because the odds ratio is not affected by the baseline risk, whereas the relative risk is. Therefore, when the risk is low, the relative risk can overestimate the strength of association between the exposure and outcome.
How do you interpret an odds ratio or relative risk?
Both the odds ratio and relative risk are interpreted in a similar way. A value of 1 indicates no association between the exposure and outcome, a value greater than 1 indicates a positive association (i.e. the exposure increases the risk of the outcome), and a value less than 1 indicates a negative association (i.e. the exposure decreases the risk of the outcome). The further the value is from 1, the stronger the association.
Can odds ratio and relative risk be used interchangeably?
No, odds ratio and relative risk cannot be used interchangeably. As mentioned earlier, they measure different aspects of association and can give different results. The choice between the two measures depends on the research question and the characteristics of the data being analyzed.
What are some common mistakes in interpreting odds ratio and relative risk?
One common mistake is to assume that an odds ratio or relative risk of 2 means that the exposure doubles the risk of the outcome. This is not always the case as the interpretation of the measures depends on the baseline risk. Another mistake is to interpret an odds ratio or relative risk as a measure of causation. These measures only indicate association and do not prove causation. It is important to consider other factors and use appropriate study designs to establish causation.
  • Atomic and Condensed Matter
  • General Discussion
