What are the considerations for live load ratings in structural design?
In summary, the live load rating of 100 pounds per square foot means that the entire walking surface is designed to support this amount of weight. This is based on the assumption that the entire surface will be loaded with this amount of weight. The design of the structure may vary depending on the type of load it is expected to support. Structural engineers typically use various codes and standards to determine the safety factors for different structures and use engineering principles to design or check the structure. While there may be some rules of thumb used, a competent engineer will always rely on an engineering analysis for proper design.
soronemus
So I'm looking at some technical drawings here (mechanical engineering co-op) and the live load rating is 100 pounds per square foot (PSF) for this particular drawing. My question is this: why is it so low? Just me standing with my feet together exerts roughly 230 pounds per square foot (i'm 230lbs, my feet take up ~1 square foot). The structure this drawing depicts is regularly walked on by workers and I must be misunderstanding the concept if just standing on it exceedes its designed strength.
I'm just now learning about live load though google searches, seems to be more civil's field, so go easy on me lol.
The live loading of 100 pounds per square foot means that the entire walking surface is assumed to be loaded this amount.
For example, if the walking surface were 3 feet wide and 10 feet long, the total live load on the walkway would be:
3 ft *10 ft *100 lbs/sq.ft. = 3000 pounds
So, for this walking surface, even at 230 lbs for yourself, you would need a lot of company to get 3000 pounds of load.
You the man SteamKing.
So it is definately treated differently for structures than it is for solid parts like I usually deal with as a mechanical engineer.
When they determine that the live load rating is 100 PSF what assumptions are made? For example is that the 3000 pounds of force can be held safely at -any point- on the structure where people would be walking? Is the surface people are usually walking on such as metal grating assumed to distribute any point load evenly across adjacent i-beams?
What kind of factor of safety is used for drawings made up by PE structural engineers in manufacturing plant cases?
Do they do all of the shear/bending moment diagrams and stress calculations, fatigue strength calculations, and other number crunching for everything they approve, or do they use a lot of 'rules of thumb'?
I really can't say, since I don't have a lot of experience in designing machine parts, except for one course in Machine Design I took at college. However, the basic principles of structural analysis are the same for designing a widget, an airliner, or a supertanker: the size and type of the loading may vary somewhat across this spectrum, but the procedure for calculating the actual stress values is the same, and a lot of the same analysis tools are used as well.
The 3000 pounds of total force I used in the previous example was just to illustrate the total load which the walkway is designed to support. The load would still be assumed distributed for design purposes at 100 pounds/sq. ft. The structural details of a walkway designed to support 100 pounds/sq.ft. versus one which can support a concentrated load of 3000 lbs. would be different, however.
The response of a certain grating material, for example steel or a composite material, to a point load would require a separate analysis.
It depends on what kind of structure/mechanism is being designed or analyzed. For example, in the US, most steel structures are designed to a code of some sort, like the AISC (American Institute of Steel Construction), which gives safety factors for loads in bending, shear, and the like.
http://en.wikipedia.org/wiki/American_Institute_of_Steel_Construction
Other codes, for different structures like road bridges, come from similar organizations like AASHTO:
http://en.wikipedia.org/wiki/American_Association_of_State_Highway_and_Transportation_Officials
and there is a lot of consultation among these different associations which goes into developing design and construction standards for various structures.
Hopefully, a structural engineer with a PE would use engineering principles in designing or checking a structure, even one which is used as a walkway. There are a few rules of thumb one can use to quickly eyeball whether or not a structure is properly designed, but the competent engineer always draws his conclusions from an engineering analysis of the structure/mechanism.
Related to What are the considerations for live load ratings in structural design?
1. What is live load?
Live load is a term used in structural engineering and architecture to describe the weight or force that a structure is designed to support while in use. This includes the weight of people, furniture, equipment, and any other movable objects.
2. How is live load different from dead load?
Dead load refers to the weight of the structure itself, including the weight of the building materials and any permanent fixtures. Live load, on the other hand, is the weight or force that is not constant and can change over time.
3. Why is live load important to consider in structural design?
Live load is important to consider in structural design because it directly affects the safety and stability of a structure. If the live load is underestimated, it can lead to structural failure or collapse.
4. How is live load calculated?
Live load is calculated based on the intended use and occupancy of the structure. For example, a residential building will have a lower live load requirement than a commercial building. Building codes and standards provide guidelines for calculating live load based on the type of structure.
5. Can live load change over time?
Yes, live load can change over time as the use and occupancy of a structure may vary. For example, a building that was initially designed for residential use may be converted into a commercial space, resulting in a higher live load requirement. It is important for structures to be regularly inspected and updated to ensure they can support the current live load.
  • Mechanical Engineering
  • DIY Projects
