LM3940 regulator not putting out 3.3V
  • Thread starter radiodude
  • Tags
    Regulator
In summary: LM7805?Yes, the output of the LM7805 voltage regulator dropped down to 3V when you connected the LM3940 regulator's input to the 5V...output of the LM7805.
radiodude
I'm giving it exactly 5 volts directly from a DC Power Supply and the output voltage should be 3.3V but it's not. I don't even have anything connected to the output pin of the regulator (holding it in my hand).
It seems if
V_in < 1.5V, V_out = about 0 plus a couple millivolts
V_in >= 1.5V, V_out = V_in minus a couple millivolts
I am using an http://www.national.com/mpf/LM/LM3940.html . I've tried one from a box of them just to be sure I hadn't shorted the old one out. There's only 3 pins: V_in, Ground, and V_out...how can you mess that up?
http://www.national.com/images/pf/LM3940/1208002.jpg
I don't know what I am doing wrong as I am using some 7805s in my circuit which have no problem taking my 8volt DC and putting out 5volts.
Any suggestions? Thanks.
Have you got the caps like from the diagram in place?
That's the last thing I haven't tried yet (ordered some, waiting for them to arrive). But I didn't think the caps not being there would make a difference if I threw it a steady voltage. Could they really be the culprit? If so, why?
Yes.
It's probably singing its head off at around 40MHz...
I was amazed the first time that happened to me too...
It needs two 100nF caps, on on the input, one on the output, and probably an electrolytic too.
It seems if
I don't have time right now to check the datasheet... What are the specs for minimum input voltage, and for minimum output current?
Voltage regulators are feedback circuits, and can only be stable in certain configurations. The capacitors add poles and are necessary for stability.
Also, many regulators will not function properly unless you are pulling some current from them.
- Warren
Thank you guys for all the responses. I guess I need those caps there. I designed the board with the caps in mind but I guess my preliminary testing before I soldered them in made me feel something was wrong altogether. I'll just wait & see what happens after the caps are in. I'll be honest I'm pretty new at this so this was the first big thing I've learned & will have to keep in mind.
berkeman, I'm not sure of the minimums but I think the minimum input is 3.3V + dropout[0.31] = 3.61V? And I'm guessing minimum output current is the quiescent current [0.11mA]? Also, 73s to you. Just made General last year.
The full story is that when the 3940 regulator was connected to the output of the 7805 regulator, the output voltage of the 7805 dropped down to 3.something volts from 5 volts, which baffled me. Feedback is key word I need to remember.
Yes, the minimum input voltage is the desired output voltage plus the drop out.
The quiescent current is the current drawn by the regulator even when supplying no load. It's basically a small amount of current that's used to bias the transistors in the regulator.
Many people are surprised to learn that voltage regulators are feedback circuits, but there's really no other way to design them. Basically, the regulator monitors its own output voltage, creates an error signal, and servos the gate voltage of a big power transistor to let more or less current through to the load, regulating the voltage. The result is a feedback loop, and all feedback loops require care to maintain stability.
- Warren
FWIW the datasheet I saw listed the dropout voltage as 0.5v.
Either way it should work with a Vin of 5v.
Are you saying that the output of the LM7805 voltage regulator dropped down to 3V when you connected the LM3940 regulator's input to the 5V rail? If so, there is something wrong with the LM3940, or you have the pinout wrong.
Keep in mind that the pinout is different for some regulators when they are in different packages. The pinout for the 7805 regulator is different between the TO-92 package and the TO-220 package, for example. Also, if you are using a power transistor package with a metal tab for a heat sink, that tab may not tolerate being grounded (check the datasheet to see what the tab is connected to).
FAQ: LM3940 regulator not putting out 3.3V
Why is my LM3940 regulator not putting out 3.3V?
There could be several reasons for this issue. First, check if the input voltage to the regulator is within its specified range (typically 4.5V to 20V). If it is outside this range, the regulator will not function properly. Also, make sure that the output load is not exceeding the maximum current rating of the regulator. Another possibility is that the regulator is damaged or defective, in which case it will need to be replaced.
Can the LM3940 regulator be used to regulate voltage other than 3.3V?
Yes, the LM3940 regulator can be used to regulate voltages between 1.25V and 20V, as long as the input voltage is within the specified range. However, the output voltage will need to be adjusted using the appropriate resistors in the circuit.
How do I troubleshoot a LM3940 regulator that is not putting out the expected voltage?
Start by checking the input voltage and load on the regulator, as mentioned in the first question. If those are within the correct range, check for any loose connections or damaged components in the circuit. You can also try replacing the regulator with a new one to see if that solves the issue. If not, there may be a problem with the circuit design or layout that needs to be addressed.
Can the LM3940 regulator handle high input voltages?
The LM3940 regulator can handle input voltages up to 20V. However, it is recommended to keep the input voltage as close to the desired output voltage as possible to maximize efficiency and minimize heat dissipation. If you need to regulate a higher input voltage, you may need to use an external voltage divider or a different regulator with a higher input voltage rating.
How do I dissipate heat from the LM3940 regulator?
The LM3940 regulator has an internal thermal shutdown feature to prevent overheating. However, if the input-output voltage differential is too high, it may still generate excess heat. To dissipate heat, you can use a heat sink, increase the PCB copper area under the regulator, or use a higher rated regulator with better thermal properties. It is also important to make sure the regulator is not enclosed in a small, poorly ventilated space.
