Load bearing capacity of a tall column
The load-bearing capacity of an 8" x 8" x 10-foot tall white oak column can be estimated using Euler's Formula for buckling, which requires the modulus of elasticity and moment of inertia for the material. It is crucial to ensure that the load is applied at the centroid and that all units are consistent for accurate calculations. A design factor of safety is typically applied, and the actual load should ideally be less than half of the critical load to ensure safety. The applicability of Euler's formula depends on the slenderness ratio and end support conditions, as uneven support can lead to failure. For precise calculations and safety, consulting a Structural Engineer is recommended, as various factors can significantly influence allowable stress in wood.
Barnsaver
Could someone please tell me the load bearing capacity of an 8" x 8" x 10 foot tall white oak column. The oak is fully cured and would be placed on an appropriately sized concrete footing. It would be mechanically fastened to a beam that it would be supporting.
Any assistance or explanation with the calculation would be sincerely appreciated. Thank you.
If we consider the base as "fixed", and the opposite end as "free" end condition. Then the critical load from Euler's Formula:
$$ P_{cr} = \frac{ \pi^2 E I}{L_e^2} $$
Where
## P_{cr} ## is the critical load for the onset of buckling
## E ## is the Modulus of Elasticity for your material ( oak - white oak - if you can find it )
## I ## is the moment of inertial about the centroid of your 8 in square column ##= \frac{1}{12} b^4 ##
## L_e ## is the effective length of the column for the given end condition ## = 2 L ##
## L ## is the height of the column
Make sure you convert all your units so they are consistent.
This model assumes the load is not eccentric ( i.e it can be effectively applied at the centroid of the column cross section )
Also, in practice there is most likely a Design Factor of Safety applied (depending on the application and material type)
You're probably ok if the actual load is less than half of the critical load, but I wouldn't say for sure.
You should consult a Structural Engineer for more accurate information on column design and applicable code, or if this thing collapses (because the actual loading situation was not accounted for) people could be seriously injured.
Likes russ_watters and Lnewqban
Before using the Euler formula, it is necessary to calculate the slenderness ratio to find if the Euler column buckling formula is applicable. The end support conditions are critical - uneven support can cause big problems.
If the Euler formula does not apply, it is a simple compressive stress problem. But even a simple compressive stress problem is critically dependent on a correct value for allowable stress. Allowable stress for wood varies widely depending on grain direction, defects, knots, moisture content, and other variables.
A complete and correct answer would require more information and a deeper engineering analysis, and is beyond what PF does. Therefore, and for liability reasons, this thread is closed.
Likes russ_watters and erobz
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
