Load Calculation Safely Supported
In summary, assuming a safety factor of 6, a mild steel column with a cross section of 100mm by 50mm can safely support a load of 400 kN if buckling is not a factor. The maximum compressive stress value used is 480 MPa.
sperrya
A mild steel column has a cross section of 100mm by 50mm. Assuming a safety factor of 6 calculate the load that it can safely support.
Column material: mild steel
Column cross section: 100mm x 50mm
Safety factor: 6
On the basis that the tensile strength of steel is equivalent to its compressive strength and that there is no compressive stress value provided in the tables of my study module. I have used the average tensile stress value which is provided in my study material.
∴ Tensile stress of mild structural steel: 430 to 510 N/mm2
∴ Average tensile stress of mild structural steel: 470N/mm2
Is this correct?
Area = 100mm x 50mm = 5,000mm2
σ = 470N/mm2 x 0.167 = 78.49N/mm2
∴ Load = Aσ
∴Load = 5,000mm2 x 78.49N/mm2 = 392,450N
Therefore the safe load that the column can support is 392,450N.
Is this correct, any help on this would be much appreciated.
Thanks
That is the safe load if the column is in tension or if it is 'short' in compression. Long columns in compression are governed by buckling strength which requires knowledge of its length to solve. Safe buckling loads for long slender
columns are independent of
the material yield or ultimate stress
Hi PhanthomJay,
Thanks for your reply.
Considering your advice, is it as simple as follows then:
P = AσK
Where:
P is safe working load - ?
A is sectional area - 100mm x 50mm = 5000mm2
σ is ultimate strength of material (mild steel) - 480N/mm2
K is fraction - 1/6 or 0.167
Therefore:
P = 5000 x 480 x 0.167 = 400,800N or 400.8kN
Can you confirm this is correct or am I missing something?
Thanks in advance
This is the safe load if the column is in tension (usually columns are in compression). This is also the safe load if the column is in compression but ONLY IF it is relatively 'fat and short'. If it is a long column, Euler Buckling may apply, that is, the allowable compressive load is (0.167) pi^2 E I /(kL)^2, where k is determined from the support conditions.. But since you do not state the value of L, the problem can't be solved unless you assume that the column is short enough so that buckling is not a factor.
Hi again PhanthomJay,
the question is this:
"A mild steel column has a cross section of 100mm by 50mm. Assuming a safety factor of 6 calculate the load that it can safely support."
So with this in mind, the length is not stated. So assuming buckling is not required in the answer to this question have I correctly answered it? Or do I need to look at anything else?
Thanks again
If buckling is not a factor, your answer is correct...short solid steel rectangular sections have the same maximum compressive stress values as the max tensile stress, which you are assuming to be 480 MPa. Please round off your answer to 400 kN.
Thank you very much PhanthomJay, your help is much appreciated!
Related to Load Calculation Safely Supported
1. What is load calculation safely supported?
Load calculation safely supported is a process of determining the maximum amount of weight that can be supported by a structure or system without causing damage or failure. It takes into account various factors such as the type of material, geometry, and environmental conditions to ensure safe operation.
2. Why is load calculation safely supported important?
Load calculation safely supported is important because it ensures the structural integrity and safety of a system or structure. Without proper load calculations, there is a risk of overloading and potential failure, which can lead to serious consequences such as injuries or damage to property.
3. Who is responsible for performing load calculation safely supported?
The responsibility for performing load calculation safely supported typically falls on the design engineer or structural engineer. They have the knowledge and expertise to calculate and determine the appropriate weight limits for a structure or system based on industry standards and regulations.
4. What factors are considered in load calculation safely supported?
Factors that are commonly considered in load calculation safely supported include the type and properties of the materials used, the geometry and design of the structure, the expected load distribution, and any environmental factors such as wind or seismic activity.
5. How is load calculation safely supported performed?
Load calculation safely supported is typically performed using mathematical calculations and computer-aided design (CAD) software. The engineer will input the relevant information and parameters to determine the maximum safe load that can be supported. They may also conduct physical tests and simulations to validate their calculations.
11K
24K
