Localization - Dummit and Foote, EXAMPLE 2, Ch. 15, Section 15.4, page 708
In summary: I think I can get started on (c) now.In summary, Dummit and Foote assert that if f is not nilpotent, then f becomes a unit in R.
Math Amateur
MHB
3,998
48
I am reading Dummit and Foote, Example 2 of Section 15.4, page 708.
Rewriting the assertions of the example as exercise style questions, EXAMPLE 2, reads as follows:
Let R be any commutative ring with 1 and let f be any element of R. Let D be the multiplicative set \(\displaystyle \{ f^n \ | \ n \ge 0\} \) of non-negative powers of f in R.
Define \(\displaystyle R_f = D^{-1}R \).
(a) Show that \(\displaystyle R_f = 0 \) if and only if f is nilpotent.
(b) Show that if f is not nilpotent, then f becomes a unit in R
(c) Show that \(\displaystyle R_f \cong R[x]/(xf -1)\)
I can manage (a) and (b) I think - my attempts follow - but need help to get started on (c)
Attempt at (a)
\(\displaystyle R_f = \{ r/d \ | \ r \in R, d \in D \} \)
where r/d = s/e if and only if x(er - ds) = 0 for some \(\displaystyle x \in D \)
\(\displaystyle f \) nilpotent \(\displaystyle \Longrightarrow f^m = 0 \) for some \(\displaystyle m \in Z^+ \)
\(\displaystyle \Longrightarrow \ 0 \in D \)
\(\displaystyle \Longrightarrow \ R_f = D^{-1}R = \{ 0 \} \)
Attempt at (b)
\(\displaystyle R_f = \{ \frac{r}{f^m} \ | \ r \in R, f^m \in R_f = D^{-1}R \)
Now \(\displaystyle f \in R_f \Longrightarrow \ \frac{f^1}{f^0} \in R_f \Longrightarrow \ \frac{f^1}{1} \)
But we have \(\displaystyle \frac{1}{f^1} \in R_f \)
So f is a unit in \(\displaystyle R_f \) since \(\displaystyle \frac{f^1}{1} \times \frac{1}{f^1} = \frac{f^1}{f^1} = 1 \) where \(\displaystyle \frac{f^1}{1} \in R_f \) and \(\displaystyle \frac{1}{f^1} \in R_f \)
Can someone please confirm that arguments (a) and (b) above are OK?
Attempt at (c)
PROBLEM ... ... I cannot get started on the third assertion above ie (c) above. Can someone please help me get started on (c) ... ...
Peter
Your argument for (a) is only "one way":
$f$ nilpotent $\implies R_f = 0$.
You also need to show that:
$R_f = 0 \implies f$ is nilpotent (which isn't hard: recall that
$D^{-1}R = 0 \iff 0_R \in D$).
For part (b) it is sometimes handy to draw a distinction between $R$ and its image in $R_f$. Also, your description of $R_f$ is a bit off, it should be:
$R_f = \{r/f^m : r \in R, f^m \in D\}$
Just because $f$ is not nilpotent doesn't mean we have a monomorphism $R \to R_f$ it is still possible we have some $g \in R$ with $fg = 0$ (we only know that $g$ is NOT a power of $f$).
Also, remember that $r/1$ is an *equivalence class*, so for example to show that:
$(f/1)(1/f) = f/f = 1/1 = 1_{R_f}$ we need to find some power of $f$ such that:
$f^m(1f - f1) = 0$ (and, of course ,any $m$ will do).
In other words, $f/f$ does not EQUAL 1, but it is EQUIVALENT to its image in $R_f$.
For (c) it may be more helpful to write the ideal generated as:
$(fx - 1)$ which makes it clear $f$ is a coefficient of $x$ in $R[x]$.
To prove these two rings are isomorphic, we need an surjective homomorphism:
$\phi: R[x] \to R_f$.
The next step is to show that $\text{ker}(\phi) = (fx - 1)$.
My suggestion, try:
$\phi(p(x)) = p(1/f)$.
Is this a ring homomorphism? Is it surjective? What is its kernel?
My suggestion, try:
Thanks for the help Deveno.
I have now read and reflected on your advice regarding parts (a) and (b) - most helpful ... but just one clarification re part (b) ,,,
I see your point regarding equivalence classes,but do not fully understand the point:
"Just because $f$ is not nilpotent doesn't mean we have a monomorphism $R \to R_f$ it is still possible we have some $g \in R$ with $fg = 0$ (we only know that $g$ is NOT a power of $f$)."
Can you explain your point further and point out the exact implications/consequences of this point for the proof of (b).
By the way, is a monomorphism just an injective homomorphism?
Peter
Yes, a monomorphism (in the case of rings) is an injective homomorphism.
The point is, if $R \to R_f$ is not injective, we cannot regard $R$ as a subring of $R_f$, so it is preferrable to speak of $[r] \in R_f$ rather than $r$.
My suggestion, try:
Thanks Deveno.
So we need to use the First Isomorphism Theorem for Rings which states (Watson: Topics in Commutative Ring Theory, page 84)
Let \(\displaystyle \phi : \ R \to S \) be an onto (surjective) homomorphism from a ring S.
Then \(\displaystyle S \ \cong \ R/ker (\phi) \)
So, as you say, we need a surjective homomorphism:
\(\displaystyle \phi : \ R[x] \to R_f \) where, as established previously:
\(\displaystyle R_f = \{ r/f^m \ : \ r \in R, \ f^m \in D \} \)
Then, of course, we have, by the First Isomorphism Theorem that:
\(\displaystyle R_f \ \cong \ R[x]/ker (\phi) \)
As you say we have to show that \(\displaystyle \phi \) is a homomorphism with kernel (fx -1), and that \(\displaystyle \phi \) is surjective.
I can demonstrate the first two points, but am having trouble showing that \(\displaystyle \phi \) is surjective.
Can you help?
Note that I can see that the elements of \(\displaystyle \phi (p(x)) \) belong to \(\displaystyle R_f \).
For example, if
\(\displaystyle h(x) = 3x^2 + 5x + 2 \)
then \(\displaystyle h(1/f) = 3/f^2 + 5/f + 2 = (3 +5f + 2f^2)/f^2 = r/f^2 \) where \(\displaystyle r \in R\) and so clearly \(\displaystyle r/f^2 \in R_f \) ... ...
But we need to show that taking any element \(\displaystyle r/f^m \in R_f \) we can find a polynomial h(x) in R[x] such that:
\(\displaystyle \phi (h(x)) = h(1/f) = r/f^m \)
Can you help?
Peter
The point is, if $R \to R_f$ is not injective, we cannot regard $R$ as a subring of $R_f$, so it is preferable to speak of $[r] \in R_f$ rather than $r$.
After mentioning the isomorphism \(\displaystyle R_f \cong R[x]/(xf -1) \), D&F go on in Example 2 page 708 to say the following:
"Note also that \(\displaystyle R_f \) and \(\displaystyle R_{f^n} \) are naturally isomorphic for any \(\displaystyle n \ge 1 \) since both \(\displaystyle f \) and \(\displaystyle f^n \) are units in both rings."
I have several issues/problems with the above statement.
1. What is the exact nature of \(\displaystyle R_{f^n} \)
[I suspect that for \(\displaystyle R_{f^n} = D^{-1}R \) we have \(\displaystyle D =\{ ({f^n})^m \ | \ n \in \mathbb{z} \) and \(\displaystyle m \ge o \} = \{ f^n, \ f^{2n}, \ f^{3n}, ... \} \) and \(\displaystyle R_{f^n} = D^{-1}R \) , but I am unsure if this is correct.]
2. What is meant by "naturally isomorphic"?
[I suspect there may be some link to the natural map \(\displaystyle R \to R/I\)?]
3. Why exactly does it follow from \(\displaystyle f \) and \(\displaystyle f^n \) being units in both rings that \(\displaystyle R_f \) and \(\displaystyle R_{f^n} \) are naturally isomorphic for any \(\displaystyle n \ge 1 \)
(Note: I feel that I am not fully appreciating the significance of an element of \(\displaystyle D^{-1}R \) being a unit.)I would appreciate help/clarification of these issues.
Peter
1) Isomorphic to $R_f$.
Your suspicion is correct, the isomorphism is:
$r/f^m \mapsto r/f^{mn}$
This is an isomorphism *because* $f$ is non-nilpotent, and is because:
$\Bbb N \to n\Bbb N$ given by $k \mapsto kn$ is an isomorphism of monoids (under addition in $\Bbb N$). This is a consequence of the familiar distributive law for natural numbers.
The important part is that you verify the isomorphism is "well-defined" that is:
$r/f^m \sim r'/f^{m'} \implies r/f^{mn} \sim r'/f^{m'n}$
The isomorphism is called "natural" because you define it the same way no matter what $n$ is (in the most naive way possible). In a similar way the isomorphism:
$F[\alpha_1] \cong F[\alpha_2]$ where $\alpha_1,\alpha_2$ are both roots of the same minimal polynomial is also "natural".
Again, we can use $\Bbb Z_6$ as an example with $D = \{1,2,4\}$, we get the same ring as a result as if we had used $D = \{1,4\}$. You may wish to verify this for yourself.
In answer to your previous post:
what is $\phi(rx^n)$?
FAQ: Localization - Dummit and Foote, EXAMPLE 2, Ch. 15, Section 15.4, page 708
What is localization in mathematics?
Localization is a mathematical concept that involves creating a new ring by inverting a subset of elements in a given ring. This allows for a more precise study of the properties of the elements in the original ring.
How is localization used in algebra?
Localization is used in algebra to study the behavior of elements in a ring at a specific point or ideal. It also allows for the study of local properties, such as divisibility and units, without having to consider the entire ring.
What is Example 2 in Dummit and Foote's book on localization?
Example 2 in Dummit and Foote's book is a specific example of localization in which a polynomial ring is localized at a prime ideal. This example demonstrates how localization can be used to study the behavior of elements in a ring at a specific point.
What is the significance of Ch. 15, Section 15.4 in Dummit and Foote's book on localization?
Chapter 15, Section 15.4 in Dummit and Foote's book is dedicated to the study of localization in algebra. It provides a comprehensive overview of the concept and its applications, including examples and exercises for further practice.
Why is localization important in mathematics?
Localization is important in mathematics because it allows for a more precise study of the properties of elements in a ring. It also has applications in various fields of mathematics, such as algebraic geometry and commutative algebra, making it a fundamental concept to understand in these areas of study.
