Math Amateur
MHB
- 3,998
- 48
I am reading Watson: Topics in Commutative Ring Theory.
in Ch 3: Localization, Watson defines the quotient field of an integral domain as follows:
We begin by defining an equivalence relation on an integral domain D. Let D be an integral domain. We define an equivalence relation on the set S of "fractions" using elements of D,
S = {a/b | a, b \(\displaystyle \in \) D , \(\displaystyle b \ne 0 \)} ,
by a/b \(\displaystyle \cong \) c/d if and only if ad = bc
we turn the set of equivalence classes into a ring (actually a field) by defining addition and multiplication as follws:
[a/b] + [c/d] = [(ad + bc)/bd]
and
[a/b] . [c/d] = [ac/bd].
(***Note that the right hand sides of these expressions make sense because D is a domain and so \(\displaystyle bd \ne 0 \) ***)
In this way, Watson has explained his Definition 6.3 which reads as follows:
Definition 6.3 Let D be an integral domain. The above field F of equivalence classes of fractions from D, with addition and multiplication defined as above, is called the quotient field of D.
Watson, then generalises the above process from an integral domain to a ring R by restricting the denominators to regular elements (ie elements that are not zero divisors)). This results in the formation of the total quotient ring defined as follows:
Definition 6.5 Let R be a ring. The ring Q(R) of of equivalent classes of fractions from R whose denominators are regular elements, with addition and multiplication defined as above is called a total quotient ring of R.
Watson then generalises the process further in a process called "localization" where now denominators are allowed to be any element from a multiplicative system (or multiplicatively closed set) defined as follws:
Definition 6.6 Let R be a ring. A subset T of R is a multiplicative system if \(\displaystyle 1 \in T \) and if \(\displaystyle a, b \in T \) implies that \(\displaystyle ab \in T \) - that is T is multiplicatively closed and contains 1.
Watson then writes:
If T is a multiplicative system of a ring R, then an equivalence relation can be defined on an appropriate set S of "fractions" using elements of R
S = {a/b | a,b \(\displaystyle \in \) R, and b \(\displaystyle \in \) T}
and
a/b \(\displaystyle \cong \) c/d if and only if r(ad - bc) =0
for some \(\displaystyle t \in T \) ... ...
Watson argues that this also results in a ring ... but my problem with this construction of a ring of fractions is that the original ring R is a multiplicative system - so then one possibility is that T = R - but then how do we avoid the problem of zero divisors -i.e. in addition and multiplication we may end up with bd = 0 for b and d not equal to zero.
Can someone please clarify this issue for me?
Peter
and
Watson then writes:
and
Peter
