Locally inertial coordinates on geodesics
In summary, the conversation discusses the possibility of constructing a coordinate system in which the metric is Minkowskian along an entire geodesic, as a mathematical realization of the equivalence principle. This is known as Fermi coordinates, which were originally developed for Riemannian manifolds and later generalized to pseudo-Riemannian manifolds. Further information can be found in the section "Fermi normal coordinates" and the remarks after Eq 9.16 in the provided source.
VantagePoint72
821
34
It's a standard fact of GR that at a given point in space-time, we can construct a coordinate system such that the metric tensor takes the form of Minkowski spacetime and its first derivatives vanish. Equivalently, we can make the Christoffel symbols vanish at point. Moreover, the fact that, in general, there's no coordinate system that let's us do this simultaneously for the entire manifold is the essence of curvature.
But, is it possible to construct a coordinate system such that the metric is Minkowskian along an entire geodesic? Since geodesics are the generalization in GR of inertial motion, it seems intuitively that it should be possible to do so. According to the equivalence principle, an arbitrarily small 'laboratory' falling along a geodesic should be unable to determine if its in an inertial (in the SR sense) frame in flat spacetime or falling along a geodesic in curved spacetime. It seems to me that finding a coordinate system in which the Christoffel symbols along the geodesic vanish would be mathematical realization of this.
http://relativity.livingreviews.org/Articles/lrr-2011-7/fulltext.html
Try the section Fermi normal coordinates, and see the remarks after Eq 9.16.
It sounds like you're describing Fermi coordinates. Fermi originally did this for a Riemannian manifold, but it was later generalized to pseudo-Riemannian manifolds.
Perfect, thank you!
Related to Locally inertial coordinates on geodesics
1. What are locally inertial coordinates?
Locally inertial coordinates are a set of coordinates used to describe the motion of a particle or object in a small region of spacetime. In these coordinates, the laws of physics can be described by the principles of special relativity.
2. How are locally inertial coordinates related to geodesics?
Locally inertial coordinates are constructed along a geodesic, which is the path that an object follows in spacetime when subject to no external forces. These coordinates allow for the description of the object's motion in a small region around the geodesic.
3. Why are locally inertial coordinates important?
Locally inertial coordinates are important because they allow for the study of objects in small regions of spacetime, where the effects of gravity can be neglected. This makes it easier to apply the principles of special relativity and accurately describe the behavior of objects in these regions.
4. How do locally inertial coordinates differ from global coordinates?
Global coordinates are used to describe the entire spacetime while locally inertial coordinates are only valid in small regions. Locally inertial coordinates also take into account the effects of gravity, while global coordinates may not.
5. Can locally inertial coordinates be used in curved spacetime?
Yes, locally inertial coordinates can be used in curved spacetime. In fact, they are specifically designed for use in regions with gravitational fields, which cause spacetime to be curved. These coordinates allow for the effects of gravity to be accounted for in the description of an object's motion.
