JavaScript Localstorage not getting cleared by window.localStorage.clear()
  • Thread starter Thread starter shivajikobardan
The discussion revolves around a JavaScript project involving localStorage and a counter. The user modified the code to manage a counter that increases, decreases, and clears values stored in localStorage. However, they encountered an issue where, after clearing localStorage, the counter continued to decrease from a previous value instead of resetting to zero. The confusion stemmed from the use of global and local variables named "count." It was clarified that the localStorage value persists even after clearing it unless explicitly reset in the code. The user later updated their code to reset the count variable to zero in the clearCounter function, which resolved the issue. The conversation also touched on the purpose of using localStorage, questioning its necessity if the count variable is reset within the script. The importance of using localStorage to maintain state across page reloads was highlighted, indicating that while resetting the variable works, localStorage serves a different purpose by retaining data even when the page is refreshed.
shivajikobardan
TL;DR Summary
localstorage not getting cleared by window.localStorage.clear()
Initial code is here:
https://www.makeuseof.com/localstorage-javascript/
It's the project that I'm trying to understand. It's the javascript that I'm concerned.I tweaked the Javascript code to this:
Code:
var count = 0;
function increaseCounter() {
  count += 1;
  window.localStorage.setItem("count", count);
  document.getElementById("score").innerHTML = count;
function decreaseCounter() {
  count -= 1;
function clearCounter() {
  window.localStorage.clear();
  document.getElementById("score").innerHTML = "";
This is what I've tweaked
I don't get the need for the commented line in this case. Why're we using it? I by now of course know it's needed. But can't understand why.
I'm facing a problem
1) I increase count to 13.
2) I clear localstorage.
3) I click decrease score. Now, score starts to decrease from 12. So, storage isn't being cleared right?
Why's it like that?
Dry run in the above code seems fine.
1) Initial count=0
2) Click increase count button
3) count=1
4) Again click increase count button
5) count=2
6) Now I clear Counter, count should be 0.
7) I click decrease counter
8) count=-1
and so on.
What am I missing here?
Technology news on Phys.org
You are missing the "javascript" language setting for your code box.
Why do you think the value in localstorage is not being cleared? How could you find out?
It looks to me like there are three variables named count: the global one at the top of the code, and the other two local variables in the increaseCounter() and decreaseCounter() functions. By commenting out the first line of code in these two functions, these functions are now using the globally defined counter variable. If the same two lines are uncommented, the local count variables override the global one.
Simple, clearing the localStorage doesn't reset the variable count.
In your link, they use the function localStorage.getItem. Pretty important detail.
open console Ctrl+Shift+J and go to Application=>Local Storage. See there.
Well I meant how could you find out in your code, but OK, what happens when you do look in the debug console?
localstorage IS being cleared so something else must be wrong
which others have already revealed
please read the question. I've explained everything there. count is not being decreased to 0.
You don't understand: I know exactly what you have done wrong, I am trying to help YOU to work out for yourself what it is. But others have told you what is wrong anyway and how to fix it.
oh. count is not being decreased to 0 when local storage is being cleared.. that's the issue. I'm not getting that.
Update:
This is my project for localStorage.
JavaScript:
var count = 0;
// var count = Number(window.localStorage.getItem("count"));
count += 1;
count -= 1;
count = 0;
This code works now. But is there a point of using localstorage if I'm going to do like this? My goal for asking the question was to understand the first line.
JavaScript:
I didn't get what we did here and why we did here.
Why should anyone bother to help you if you can't be bothered to set the language to Javascript in your code blocks as you have been repeatedly asked?
I've gave JS tag already. Still edited where I could edit.
Thank you.
No, not if you are going to do it like this. But there is something different about a browser's localStorage from a variable in a script: what do you think this is?
