Logarithm state the value of x for which the equation is defined
In summary, the equation ##\ \log_x(5)+2\log_x2-\log_1/x2=3## is defined for certain values of x. The equation can be solved for x by using the change of base formula.
Jaco Viljoen
160
Consider the equation:
3logx5+2logx2-log1/x2=3
a)State which values of x for which the equation is defined.
b)Solve the equation for x.
=logx53+logx22-log1/x2=3
=logx125+logx4-log1/x2=3
=logx500-log1/x2=3
=logx2=logx2/logx(1/x)change of base
=-logx2
=logx125+logx4+logx2=3
=logx500+logx2=3
=logx1000=3
=x3=1000
x=10
Please check if you don't mind?
Likes Tony Mondi
=logx125+log4-log1/x2=3
=logx500-log1/x2=3
=-logx2
=logx125+log4+logx2=3
=logx500+logx2=3
=logx1000=3
=x3=1000
x=10
Not too difficult to check.
becomes:
3log105+2log102-log1/102=3 .​
See if the following is true.
##\displaystyle\ 10^{\displaystyle\left(3\log_{10}(5)+2\log_{10}(2)-\log_{1/10}(2)\right)}=10^3\ ##​
Yes it works.
I don't understand what 9.1 wants me to do?
Jaco Viljoen said:
Yes it works.
What's 9.1 ?
For what values of x does logx(something) make sense? Same question for log1/x(something).
Several ways to figure this out.
1. From definition of the logarithm.
What does it mean, particularly for base, b, if logb(A) = C ?​
2. From change of base, along with knowing the domain of the logarithm function.
What are logx(A) and log1/x(A) ?​
logb(A) = C
bC=A
x>1
Jaco Viljoen said:
logb(A) = C
bC=A
x>1
Doesn't that mean that 1/x < 1 ?
x>=3
Still let's 1/x < 1 ! But: is that a problem ?
Try to put SammyS' question 1 in words.
Jaco Viljoen said:
logb(A) = C
bC=A
What are the restrictions on the base, b, if C and A are to be real numbers?
I think the change of base route might lead to the answer more quickly, but if you're to understand logarithmic & exponential functions, then eventually you need to confront this issue regarding the base.
a logarithm is undefined when x<0
1/x will be 1/3 but still x>0 so the logarithm will be defined.
x>0
x>0
I don't see what 1/3 has to do with anything here.
Yes, as you state, "a logarithm is undefined when x<0." ... and, yes, "x > 0" .
Now, are you referring to the base of the logarithm ?
Yes, the base of log cannot be smaller than 0
Can it be zero ?
Why or why not?
It is not defined, cannot be calculated, gives an error.
Its a rule
Its a rule
What is not defined?
the logarithm
Jaco Viljoen said:
the logarithm
Please make a complete statement.
What logarithm is not defined?
The real logarithmic function logb(x) is defined only for x>0. So the base b logarithm of zero is not defined.
This is precisely why we needed you to make a full statement here.
The question (in Post #1) refers to x.
In this problem, x appears, not as the argument of the logarithm, but appears as the base, as well as 1/x appears as the base.
Likes Mark44 and Jaco Viljoen
Thank you so much for all your help.
Have a great night.
Jaco
Is the log function logb(x) defined if b = 1?
Edit: Fixed my bonehead typo of "if x = 1"
Likes Jaco Viljoen
i have tried to follow the steps i am also having a problem in stating the values of x for which the equation is defined
Please Help
Hello Mondi, Welcome to PF.
The original question had to do with the values of x for which ##\ \log_x(5)\ ## and ##\ \log_{1/x}(2)\ ## are defined.
Use the change of base formula to help answer this.
If I were doing this problem, I would start out by writing
$$3\log_x5=y$$
or, equivalently,
$$\log_x125=y$$
So,
$$x^y=125$$
If I take the natural log of both sides, I get:
$$y=\frac{\ln125}{\ln x}$$
So,
$$3\log_x5=\frac{\ln125}{\ln x}$$
Similarly $$2\log_x2=\frac{\ln4}{\ln x}$$
and
$$\log_{1/x}2=\frac{\ln2}{\ln (1/x)}=-\frac{\ln2}{\ln x}$$
Chet
Likes Jaco Viljoen
Mark44 said:
Is the log function logb(x) defined if x = 1?
Edit (Mark44): I meant "if b = 1". I have since fixed what I wrote earlier. The base can't be zero and it can't be 1.
Hi Mark,
I thought so but when I checked, NO.
The rule states:
x>0 and not = to 1
Thank you for pointing that out.
Jaco
Jaco Viljoen said:
Hi Mark,
The rule states:
x>0 and not = to 1
Jaco
This is the second time you have posted this and it still is NOT true. Where did you find that rule? For any base, b, [itex]b^0= 1[/itex] so [itex]log_b(1)= 0[/itex]. That certainly is defined!
  • #31
Jaco Viljoen said:
Hi Mark,
The rule states:
x>0 and not = to 1
Jaco
The base, b, must be positive, but can't be 1. ( I suppose Mark had a typo.)
  • #32
Hi Hallsoflvy,
I am not referring to logbx but to the problem where x is the base:
Sammy,
I understood what Mark was saying the base must be positive but can't be 1.
  • #33
I see that you liked what I posted in #28. Does that mean that you figured out how to use it to solve the problem? If so, please show us what you did.
Chet
  • #34
Chet
Hi Chet,
I was thanking you for your interest and alternative option, I will however give it a bash:
what rule did you apply or why did you use ln?
$$\frac{\ln125}{\ln x}+\frac{\ln4}{\ln x}+\frac{\ln2}{\ln x}=3$$
$$\frac{\ln1000}{\ln x}=3$$
$$ln1000=3lnx$$
ln(x)3=ln1000
x3=1000
103=1000
so x=10I am not sure if I have done the right thing... Please advise
  • #35
Jaco Viljoen said:
Hi Chet,
$$\frac{125}{\ x}+\frac{4}{\ x}+\frac{2}{\ x}=3$$
$$\frac{125+4+2}{\ x}=3$$
$$\frac{131}{\ x}=3$$
$$131=3x$$
$$\frac{131}{\ 3}=x$$
$$x=43\frac{2}{\ 3}$$
Well, your first equation is correct, but that's about all. Going from your first equation to your second equation is definitely not how logs work.
Did you notice that the three terms on the left hand side of your first equation have a common denominator. What do you usually do in an algebra problem or arithmetic problem when you have the sum of three separate terms, all of which have the same denominator?
Chet
