Logarithmic Regression Question (TI-84 Plus Graphing Calculator)
  • Thread starter Thread starter MeesaWorldWide
    equation Regression
The discussion revolves around determining the best logarithmic regression equation for bean plant growth data using the TI-84 Plus graphing calculator. The initial equation obtained from the data, y = 3.22 + 1.07Lnx, was derived without switching x and y values, but a second equation, y = -17.30 + 15.60Lnx, is suggested as the "best" fit after switching the variables. The user questions the necessity of this switch, as the first equation already reflects a logarithmic trend. Additionally, there is a query about whether the calculator can provide a goodness-of-fit measure, such as the Coefficient of Determination (R²), to compare the two equations. The discussion highlights confusion over variable definitions and the rationale behind switching x and y for regression analysis.
MeesaWorldWide
Thread moved from the technical forums to the schoolwork forums
TL;DR Summary: Exponential VS Logarithmic Regression (using the TI-84 Plus graphing calculator)
Here is the question:
A scientist examines the growth of bean plants under different growing conditions. The results of one trial are as follows:
Day: 1 3 5 9 11 15
Average height of bean plants (cm) 3.2 4.6 5.4 4.2 5.5 7.1
Determine a logarithmic equation that best represents the data.
I have entered this data into my calculator lists and used logarithmic regression (LnReg) to obtain the equation y = 3.22 + 1.07Lnx
However, the actual answer supposedly requires me to switch the x and y values (inverse), and then use LnReg on that, which produces a different equation: y = -17.30 + 15.60Lnx
I don't understand why I need to switch the x and y values if the data points already trend in a logarithmic fashion. The fact that I was able to use LnReg on the data to get an equation without switching the values should be enough, no? Why is is better to switch x and y first? Why can I not just use the first equation I found (which didn't involve switching anything)?
Thanks in advance for any clarity you can provide.
Your data is "Day" and "Height" but your equations are in terms of variables ##x## and ##y## which you never define!
Sorry, should have clarified. If you are familiar with doing regression on a TI-84 calculator, there are two lists (L1 and L2) that the data gets entered into. I entered my time (Days) into L1 (x-axis) and my heights into L2 (y-axis). I am unsure why they need to be switched to get the best answer since I already get a logarithmic equation when Days is the independent variable and height is the dependent variable. My second equation that I stated is the supposed 'best' answer, but it has Days on the y axis and the height is the independent variable (?) which doesn't really make sense by itself.
Note that the question itself never defines for me which variables is x and which is y. The questions is written exactly as I typed it out here.
Sorry, I am not familiar with the operation of the TI-84+ calculator. Can it quantify "the goodness of fit" by displaying, e.g., the Coefficient of Determination ##R^2## for each of the two logarithmic fits? If so, which fit has the higher value?
Their answer is bad for the reason that the errors that are sum-square minimized by the regression are the wrong errors.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
