Logic applied to making isothermal assumption
In summary, the thin heater is inserted between the long rod and the concentric tube with inner and outer radii of 20 and 40 mm. The rod has a thermal conductivity of kA = 0.15 W/(m*K), while the tube has a thermal conductivity of kB = 1.5 W/(m*K) and its outer surface is subjected to convection with a fluid of temperature T∞ = -15°C and heat transfer coefficient 50 W/(m2 *K). The thermal contact resistance between the cylinder surfaces and the heater is negligible.
rhm95
A thin electrical heater is inserted between a long circular rod and a concentric tube with inner and outer radii of 20 and 40 mm. The rod (A) has a thermal conductivity of kA = 0.15 W/(m*K), while the tube (B) has a thermal conductivity of kB = 1.5 W/(m*K) and its outer surface is subjected to convection with a fluid of temperature T∞ = -15°C and heat transfer coefficient 50 W/(m2 *K). The thermal contact resistance between the cylinder surfaces and the heater is negligible.
(a) Determine the electrical power per unit length of the cylinders (W/m) that is required to maintain the outer surface of cylinder B at 15°C.
(b) What is the temperature at the center of cylinder A?
Rconv = 1/(hA)
Rconduction = ln(r2/r1)/(2piLk)
Q=delT/R
a) Q is constant throughout cylinder.
L=length of cylinder
Rconv = 1/(50*2pi*.04*L)=.07958/L
Ts=outer surface temp
Q/L = (Ts-Tinfinity)/(L*Rconv) = 376.98 W/m
b)
T1 is temperature of the inner surface
Q/L=(T1-Ts)/(Rconduction*L)
Rconduction = ln(.04/.02)/(2*pi*L*1.5)=.07355/L
T1=(Q/L)*(Rconduction*L)+Ts = 42.73C
The answer for temperature at the center is 42.73 which is also the temperature of the outer radius of the rod.
What leads one to an isothermal assumption that allows for correct calculation?
The steady state heat conduction equation for the rod is:
$$\frac{1}{r}\frac{d}{dr}\left(r\frac{dT}{dr}\right)=0$$
If we integrate this once, we obtain: $$r\frac{dT}{dr}=C$$where C is a constant. Integrating again gives:
$$T=C\ln(r)+D$$where D is another constant. If the temperature is finite at r = 0, then C must be equal to zero. Therefore, T = D = const.
Another way of answering this question is this: If a conductive body is surrounded over its entire surface by a temperature To, how can its interior temperature at steady state be anything but To?
Related to Logic applied to making isothermal assumption
1. What is an isothermal assumption and how is it applied in logic?
An isothermal assumption is a logical concept that assumes a system or process is at a constant temperature. In logic, it is used to simplify complex systems or arguments by assuming that temperature is not a factor in the analysis. This allows for more straightforward reasoning and conclusions to be drawn.
2. What are the limitations of using an isothermal assumption?
One limitation of using an isothermal assumption is that it may not accurately reflect the real-world conditions of a system or process. Temperature can play a crucial role in many systems, and by assuming it to be constant, important factors may be overlooked. Additionally, an isothermal assumption may not hold true for systems with significant temperature variations.
3. How do scientists determine when it is appropriate to make an isothermal assumption?
Scientists must carefully consider the system or process they are analyzing before making an isothermal assumption. They must assess the potential impact of temperature on the results and determine if it is necessary to account for it or if it can be simplified by assuming a constant temperature.
4. Can an isothermal assumption be applied to all systems and processes?
No, an isothermal assumption may not be applicable to all systems and processes. It is typically used in thermodynamics and other fields where temperature is a significant factor. However, in other areas of science, such as biology or ecology, temperature may not have a significant impact, and therefore, an isothermal assumption may not be necessary or appropriate.
5. How does making an isothermal assumption affect the accuracy of scientific conclusions?
The accuracy of scientific conclusions may be affected by making an isothermal assumption. By assuming a constant temperature, potential variables and factors may be overlooked, leading to incomplete or inaccurate conclusions. Therefore, scientists must carefully consider the impact of temperature and determine if an isothermal assumption is appropriate for their analysis.
  • Thermodynamics
