Logic- How to show something is NOT provable?
  • Thread starter hatsu27
  • Tags
    Logic
In summary: Also how does showing ƒ(A) = T prove that I need propositional axioms to prove ~~(x =x) V ~(x = x)? Am I even on the right track here? How does one show something is not provable? It's easy to show provability, I only need one instance to make something true, I don't know how to do it the other way around!
hatsu27
Let S be the theory with no NONlogical symbols and no NONlogical axioms.
Show that ~~(x = x) V ~(x = x) is a theorem of S NOT provable without propositional axioms.
Let ƒ be a mapping from the set of formulas to the set of truth values such that ƒ(A) = T for A atomic; ƒ(~A) = F; ƒ(A V B) = ƒ(B); ƒ(∃xA) = T. Show that if A is provable without propositional axioms then ƒ(A) = T.
OK, so here are my thoughts:
First I assumed that A = ~~(x = x) V ~(x = x) which is itself a propositional axiom, but then if that is so than what is B? so then should I set A = ~~(x = x) and B= ~(x = x)? now then can I use contradiction to prove this? Set ƒ(A) = F, then f(~A) = T and then ƒ(A V B) = ƒ(B) would allow ƒ(B) to be true since A is false. This also makes sense since ~A is really just B and ~A is true. But then (A V B) = (A V ~A) which is a propositional axiom-- the very thing I am not supposed to use!
So then I thought: suppose (A V B) and B are valid then ƒ(A V B) = ƒ(B) = T. then breaking down ƒ(A V B) then ƒ(A) = T or ƒ(B) = T. Now we know that ƒ(B) = T because it is part of our supposition, but since ƒ(∃xA) = T and ƒ(~A) = F then ƒ(A) must also be true.
Third thought was suppose ƒ(B) = F, then ƒ(A V B) = ƒ(B) = F then the only was for
ƒ(A V B) = F to be valid is if both A and B are false, but since we know that ƒ(∃xA) = T then
(A V B) cannot = F and since B does = F then A must = T therefore ƒ(A) = T.
Now I now that there is faulty logic in each of these scenarios, but am I close somewhere? Also how does showing ƒ(A) = T prove that I need propositional axioms to prove
PS- this problem comes from Shoenfield's Mathematical Logic book.
Presumably, you're permitted to use the theorem listed under "Relevant equations"?
If so, let ##f## be as in the theorem; i.e. (and I'm using different symbols for a reason here) ##f(a)=T## and ##f(\lnot a)=F## for ##a## atomic and ##f(b\lor c)=f(c)## for all formulas ##b## and ##c##.
1. What kind of formula is ##x=x##?
2. What can you say about ##f(x=x)##?
3. What can you say about ##f\big(\lnot(x=x)\big)##?
4. Supposing, towards a contradiction, that ##\lnot\lnot(x=x)\lor\lnot(x=x)## is provable without propositional axioms, what can you say, based on the theorem, about ##f\big(\lnot\lnot(x=x)\lor\lnot(x=x)\big)##?
5. What does your answer in 4 say about ##f\big(\lnot(x=x)\big)## (remember ##f(b\lor c)=f(c)##)?
Remark 1: The ##f## from the theorem is not a "truth function". However this fact is not relevant to the problem.
Remark 2: It is completely unnecessary in this problem to use the "meanings" of the symbols ##\lnot,\lor,T,F##. In fact, presuming to know what those symbols "mean" is likely to lead to some confusion.
First off thank you for responding- I really appreciate your help- I am taking this as an independent study course and with no lectures and a Prof. who doesn't have a lot of time for me it can be frustrating and lonely! If anything it is nice to have someone just answer a question:redface:
Ok so I have been trying to think about your questions without seeing the meanings of not, or, T, F.
1) x = x is an equality formula such that every natural number is equal to itself.
2) ƒ(x = x) then is a function in which every natural number in this particular function is equal to itself.
3) ƒ(~(x = x)) is also an equality function? Since I am to ignore the ~, it is still just an equality function as in (2).
4) so then ƒ(~~(x = x) V ~(x = x)) is also just an equality function? It doesn't matter what is going on around it x will always equal x?
5) then, well I'm not sure what you mean here so I figure I am looking at this all wrong, but again maybe same concept as above? that x will equal what you set it to no matter what since you define x yourself?
I guess the way I look at the formula (~~(x = x) V ~(x = x)) is that it is similar to ∃xA, allowing some of the meanings to come back in, there are some times that (x = x) works and other times when it doesn't. Am I looking at this in the wrong way again?
Ok. Your answers are not what I expected.
The ##x## that is written in my post (and I'm guessing the text that you're reading) is basically a variable symbol of the formal language that we're working with. At present, it is completely meaningless. Similarly, the ##=## in the formula ##x=x## is a meaningless (for now) logical symbol that is treated like a binary relation symbol; that is for all variables ##x## and ##y##, the string ##x=y## is a well-formed/valid formula in the empty language (i.e. the language with no non-logical symbols). In fact ...
(1) ##x=x## is an atomic formula in the empty language.
Now ##f## is a function whose domain consists of formulas in that language. ##f(x=x)## is the result of applying that function to the formula ##x=x##. Since ##x=x## is atomic and we have presupposed that ##f(a)=T## for all atomic ##a##, we can say that
(2) ##f(x=x)=T##.
Now is that enough to get you going on the rest of my questions?
Ok I will try again (thanks for your patience with me)
1) x=x just an atomic formula
2) ƒ(x = x) = T
3) ƒ(~(x = x)) = F
4) then (~~(x = x) V ~(x = x)) is a wff, a string of atomic formulae?
5) then remembering ƒ(B V C) = ƒ(C) : ƒ(~~(x = x) V ~(x = x)) = ƒ(~(x = x))...?
4) Then again maybe because (~~(x = x) V ~(x = x)) is a wff, so ƒ(~~(x = x) V ~(x = x)) = T
5) and if that's true then if ƒ(~~(x = x) V ~(x = x)) = ƒ(~(x = x)) = T, then ƒ(~(x = x)) is just the function of a wff as well so it = T, thus we have contradiction?
Is this closer?
hatsu27 said:
3) ƒ(~(x = x)) = F
Correct, because that's what ##f## does to negations of atomic formulas.
Well, yes. All wffs are built from atomic formulas. I wouldn't call it a string of formulas. From what I can tell looking at the first few pages of your text on Amazon, my string is the same as his expression.
Here we're supposing, in order to hopefully derive a contradiction, that this particular wff is provable without propositional axioms. What does ##f## do to formulas that are provable without propositional axioms? What does that say about ##f\big(\lnot\lnot(x=x)\lor\lnot(x=x)\big)##?
Right. Now put that together with what you (hopefully) discovered in (4) and tell me what ##f\big(\lnot(x=x)\big)## is. Remember, we're trying to get a contradiction, so your answer here will likely contradict an earlier answer.
Is this closer?
Here you're getting closer, saying a lot of things that are true and relevant but not necessarily for the right reasons.
Related to Logic- How to show something is NOT provable?
1. What is the definition of "provable" in logic?
"Provable" in logic means that a statement or proposition can be logically derived from a set of axioms or premises using accepted rules of inference.
2. How do you prove that something is not provable?
In order to prove that something is not provable, you must show that it contradicts a fundamental axiom or rule of inference. This can be done through a counterexample or by demonstrating that the statement leads to a logical contradiction.
3. Can something be both provable and not provable?
No, a statement cannot be both provable and not provable in the same logical system. It is either provable or not provable, but not both.
4. Are there different levels of provability in logic?
Yes, there are different levels of provability in logic. Some statements may be provable with certain sets of axioms but not with others, and some may require more complex rules of inference to prove.
5. How does Gödel's incompleteness theorem relate to proving something is not provable?
Gödel's incompleteness theorem states that in any consistent formal system, there will always be statements that are true but not provable within that system. This means that there will always be some statements that are not provable, no matter how powerful the logical system is.
