MHB Logic, proving theorem in formal system K
The discussion revolves around proving the theorem $A(a_1) \rightarrow (\exists x_1) A(x_1)$ within the formal system K_L. A participant highlights the challenge of manipulating quantifiers due to the free variable $x_1$ in $A$. They suggest that while equivalent logic can be tempting, it undermines the goal of deriving the theorem within a formal system. The conversation also notes the difficulties of using the Hilbert system for proofs, advocating for natural deduction as a more user-friendly alternative. Lastly, there is a proposal to explore the contrapositive approach to leverage existing axioms effectively.
Barioth
Hi
here is the problem I'm working on,
Let $A(x_1)$ be a well formed formula of a language $L$ in which $x_1$ is free, let $a_1$ an invidual constant of $L$, Show that the formula $A(a_1)\rightarrow(\exists x_1)A(x_1)$ is a theorem of $K_L$
on this link, the first slide as the axiom of $K_L$
http://www.idi.ntnu.no/emner/tdt4135/handouts/slides-9.pdf
I wanted to use the following proof:
is equivalent logic to
$(\exists x_1)(A(a_1)\rightarrow A(x_1))$
wich is equivalent logic to
$(\forall x_1)A(a_1)\rightarrow A(x_1)$
then trying to conclude using (K5) from the pdf link,
but I just realized that since $x_1$ is free in A, I cannot move the quantifier like I did.
By "equivalent logic" you may mean "logically equivalent", that is, the formulas logically imply each other. But an appeal to semantics defeats the purpose of proving that a formula is a theorem in a formal system. For this you need a derivation.
Next, system K (Hilbert system) is almost impossible to use for building proofs (though it is easy to prove things about it), at least until a significant number of metatheorems, like the deduction theorem, is proved. You may be stuck if your course or book uses it, but I would recommend some version of natural deduction, which is much more user friendly. The metatheorems I talked about make Hilbert system more like natural deduction anyway.
Also, axioms you gave don't use the existential quantifier. Doe this mean that $\exists x\,A$ is a contraction for $\neg\forall x\,\neg A$? If so, one idea is to prove the contrapositive
\neg\neg\forall x\,\neg A(x)\to\neg A(a)
and then use K3. If you can derive $\forall x\,\neg A(x)$ from $\neg\neg\forall x\,\neg A(x)$, then you can just use K5.
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
Hello, I'm joining this forum to ask two questions which have nagged me for some time. They both are presumed obvious, yet don't make sense to me. Nobody will explain their positions, which is...uh...aka science. I also have a thread for the other question. But this one involves probability, known as the Monty Hall Problem. Please see any number of YouTube videos on this for an explanation, I'll leave it to them to explain it. I question the predicate of all those who answer this...
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
