Logistic Regression and utility function
tomasrrd
Hi, I am tryin to solve the following, but I think that something is missing in my understanding.
A company is trying to predict whether a product will be successful. A measurement X (real valued r.v) is made for each product. The company would like to find a threshold ##\theta## so that if ##x>=\theta## the product is supported and otherwise abandoned. Z is Bernoulli variable to model success(1) and failure(0).
The company found that ##X\sim Gamma(2.5,0.25)## and
$$ \Pr(Z=1 | X=x) = \frac {e^{(x-\mu)e^{-\gamma}}}{1+e^{(x-\mu)e^{-\gamma}}}$$
where ##\mu, \gamma## are unknown constants with flat priors.
The utility for the company:
1. product is supported and is success: ##b_1=10##
2. the product is supported and if failure: ##b_2=-6##
3. the product is abandoned: ##b_3=-1##.
One of the questions I am struggling with is:
Find a formula that computes the expected utility for a product given a specific value for ##\theta, \gamma, \mu##.
NA
I thought that the expected utility is simply the utility of an outcome multiplied by the probability of that outcome. I thought about the following:
set
$$p:=\Pr(Z=1 | X=x) = \frac {e^{(x-\mu)e^{-\gamma}}}{1+e^{(x-\mu)e^{-\gamma}}}$$
and then
$$E(utility)=[b_1⋅p+b_2⋅(1−p)]\Pr(X\leqθ)+b_3⋅\Pr(X>θ)$$
since we have the information thafdt ##X∼Gamma(2.5,0.25)##.
The problem is that p itself depends on x, and it doesn't really make sense.
I am not sure what I am missing...
Thanks in advanced.
Tomas.
It's been a real long time since I've done these, but let me ask you a question. How could utility be the sum of both supporting and abandoning the product? Since you're given the conditions for supporting or abandoning the product, ##x \geq 0## and ## x < 0##, shouldn't you have two utility functions depending on the case?
Thanks for the answer.
If I understand your remark correctly, I think that what I (kind of) tried to do in the expression ##b_1\cdot p + b_2\cdot(1-p)##
But it will still depend of the ##x## value (which depends on the product).
Another idea that I had is that for each ##\mu,\gamma##, take a large sample from ##Gamma(2.5,0.25)## and compute an approximation value for that probability. In this case, it will eliminate the dependency on ##x## and we'll get a number that could make sense. But I am not sure that this is the right way.
By the way, there is an error in the equation of the expected utility, and the expressions ##\Pr(X\leq\theta)## and ## \Pr(X >\theta) ## should be interchanged (not sure if I can still edit it).
Thank again,
Tomas.
What I mean is that your utility function U(x) should piecewise, i.e. in the case of abandoning the product the utlitly is just -1, since the probability of you abandoning it is 1. The other case would be based on the probablities that the product is a success or failure.
You could have already done this and I just got thrown by the typo.
You can then write the unconditional expected utility function and take the integral, ##E(U(x))=\int_{-\infty}^{\infty}U(x)f(x)dx##, plug everything in and you should get a final function that only depends on ##\theta##, ##\mu##, ##x##, and ##\gamma##.
Does the problem actually want you to do the numerical integration or does it actually want you to eliminate x? Or just write it in terms of ##\theta, \gamma, \mu## naturally assuming you're going to integrate over x?
So, if I understand correctly, it supposed to be as I wrote (just without the typo):
$$ E(U(x))=\int_{-\infty}^{\infty}U(x)f(x)dx = \int_{0}^{\theta}(-1)f_X(x)dx + \int_{\theta}^{\infty}(b_2(1-p) + pb_1)f_X(x)dx$$
Where ##f_X## has the described gamma density?
The next step is to do numerical integration, but I want to understand what I am actually doing.
Thanks again.
Yeah that looks like right to me.
Great. Thanks for the help :)
