Logorithms of negative numbers
In summary, the conversation discusses the concept of taking the natural logarithm of negative numbers in the context of complex numbers. It explains that while it is not possible to take the logarithm of a negative number using the principle branch of the complex logarithm, it is possible by choosing a different branch cut. A recommended internet reference for further information is provided.
SW VandeCarr
2,199
81
logarithms of negative numbers
Some years ago, I read about how to take the natural log of a negative real number but I don't remember the source. I'd to get feedback if this is correct: (::= 'therefore')
Euler's identity: e^(i pi) = -1 :: ln(-1)= i pi, and ln(-a) = ln(a) + i pi ('a' a real number) :: the natural logs of all negative real numbers would lie on a line parallel to the real axis at distance of pi on the i axis. Is this correct?
This is possible when you're dealing with complex numbers, but you have to be careful. To be analytic, the complex logarithm requires a branch cut. Traditionally, the principle value of the logarithm places this branch cut along the negative real axis, so using the principle branch of the complex logarithm, it's not possible to take the log of a negative number. However, this branch cut can be moved, resulting in other branches of the complex logarithm. Any half-line terminating at the origin can be used as a branch cut for Log, so if you wanted to take the logarithm of a negative number, you could choose the branch that is cut along the negative imaginary access.
To see this discussion of branch cuts, note that for [tex]z \in \mathbb{C}[/tex], the complex logarithm is defined as [tex]\operatorname{Log} z = \log | z | + i \operatorname{Arg} z[/tex]. The branch cut required to make the complex logarithm analytic comes from the fact that the argument has to jump from 0 to [tex]2 \pi[/tex] somewhere, and for the principle branch, that's on the negative real axis. To get a branch of the logarithm that you can use on negative real numbers, simple choose [tex]-\frac{\pi}{2}\leq\operatorname{Arg} z\leq\frac{3 \pi}{2}[/tex], which is well-defined on the negative real axis. And in that case your absolutely right, for x < 0, [tex]\operatorname{Arg} x = \pi[/tex], so [tex]\operatorname{Log} x = \log |x| + i \pi[/tex].
Thanks very much rochfor1. I was winging it since I didn't have a reference. Could you supply a good internet reference?
FAQ: Logorithms of negative numbers
What is a logarithm of a negative number?
A logarithm of a negative number is a real number that, when raised to a certain power, equals the negative number. It is the inverse operation of exponentiation.
What are the properties of logarithms of negative numbers?
The properties of logarithms of negative numbers are similar to those of positive numbers. The main difference is that the logarithm of a negative number will always be a complex number, whereas the logarithm of a positive number can be a real number.
Can a negative number be the base of a logarithm?
Yes, a negative number can be the base of a logarithm. However, the result will always be a complex number.
What is the difference between a logarithm of a negative number and a negative logarithm of a positive number?
The logarithm of a negative number is a complex number, while a negative logarithm of a positive number is a negative real number. Additionally, the logarithm of a negative number will have an imaginary component, while a negative logarithm of a positive number will not.
What are the practical applications of logarithms of negative numbers?
Logarithms of negative numbers are used in various fields of science, such as physics, chemistry, and engineering. They are also used in mathematics to solve equations involving negative numbers and in data analysis to represent data on a logarithmic scale.
