Lone Pair Electrons in Dipole Moments
In summary, lone pair electrons have a significant effect on the net dipole moment of a molecule, as they impact both the partial charges and the distance between them. This is evident in examples such as NH3 and NF3, where the lone pair electrons contribute to the overall polarity of the molecule. While electronegativities can give a general idea of the dipole moment, they do not take into account the impact of lone pair electrons. However, for simplicity, lone pair effects are often not considered in classroom applications.
chemistrysa
I had to clear this up since there were many threads with the wrong analysis of this problem. Lone pair electrons DO have and affect on dipole moments.
Lone pair electrons do have an effect on the net dipole moment of a molecule. A dipole moment is the product of the magnitude of the partial charges on the molecule and the distance in which they are separated. Lone pair electrons affect both the partial charges and the distance between partial charges.
The NH3 and NF3 are perfect examples yet are explained wrong here. Using electronegativities NF3 should have a greater dipole moment because N=3.04, F=3.98, and H=2.20. Thus the greater disparity is between N and F. However, the dipole moment of NF3 is quite small at 0.23 D (D is debye). The dipole moment of NH3 is 1.47 D. The lone pair of electrons extends into space and increases the charge separation in the molecule, thus increasing its dipole (see definition above). You can see electronegativities do NOT consider everything that must be considered for dipole moments. Lone pairs DO have an effect on the net dipole moment of a molecule (a.k.a. the polarity of the molecule).
However, for most applications in a classroom lone pair effects on a dipole moments are not considered for sake of simplicity.
Chemistry news on Phys.org
Would you mind to cite a concrete thread?
OP, how would anyone think that lone pairs are not relevant for the charge distribution in a molecule? I do not think I have heard this before. There are plenty of simple examples which clearly demonstrate that they are important. For example, it is common knowledge that in the CO molecule the "negative end" of the dipole moment is on the C atom, rather than the O atom as one might expect, simply because C's lone pairs are bigger.
Related to Lone Pair Electrons in Dipole Moments
1. What are lone pair electrons in dipole moments?
Lone pair electrons are non-bonding electrons that exist in the outermost shell of an atom. They are not involved in covalent bonding and therefore do not contribute to the overall dipole moment of a molecule.
2. How do lone pair electrons affect dipole moments?
Lone pair electrons can significantly influence the dipole moment of a molecule. If the lone pair is located on the central atom, it can create an asymmetrical distribution of charges, resulting in a dipole moment. However, if the lone pair is located on a terminal atom, it can cancel out the dipole moment created by other atoms in the molecule.
3. Do lone pair electrons always contribute to the dipole moment?
No, lone pair electrons do not always contribute to the dipole moment. As mentioned earlier, it depends on their location within the molecule. If they are located on the central atom, they will contribute to the dipole moment, but if they are on a terminal atom, they may cancel out the dipole moment.
4. Can lone pair electrons affect the polarity of a molecule?
Yes, lone pair electrons can significantly impact the polarity of a molecule. As mentioned earlier, if the lone pair is located on the central atom, it can create an asymmetrical distribution of charges, resulting in a polar molecule. However, if the lone pair is located on a terminal atom, it can cancel out the polarity created by other atoms in the molecule.
5. How can we determine the presence of lone pair electrons in a molecule?
The presence of lone pair electrons can be determined by looking at the Lewis structure of a molecule. If there are non-bonding electrons around the central atom, those are likely lone pair electrons. Additionally, experimental techniques such as X-ray crystallography can also be used to determine the presence of lone pair electrons.
  • Electromagnetism
  • Electromagnetism
30K
  • Atomic and Condensed Matter
