Longer math and physics problems
In summary, when solving a math or physics problem, it is important to first identify the type of problem and determine which equations are needed. For simpler problems, all the necessary information may be given, but for more complex problems, trial and error may be necessary. It is helpful to draw a diagram and label the variables before translating the problem into equations. With practice, a general approach for solving problems becomes more apparent.
Fascheue
When solving a math or physics problem, the process usually starts with recognizing what type of problem it is and which equations need to be used.
This is simple for more straight forward problems. If they give you mass and acceleration and ask you to find the force, you have all parts of the equation f = ma except for one.
Sometimes I find it confusing though when this is not the case, for example I had to solve a problem something like this:
There are two boats. One boat is 20 units west of the other. That boat starts moving west with a velocity of 19 units/hr. The other boat starts moving north at a velocity of 25 units/hr. What is the rate of change of the distance between the boats in 7 hours.
I eventually solved the problem, but I did so just by trying a ton of different things, many of which did not work. Eventually I set up a right triangle, with one side 20 + 19t, another side 25t, and an unknown hypotenuse. I plugged in 7 for t to get c. Then I implicitly differentiated A^2+B^2=C^2 and plugged in for all value except for the unknown dc/dt to find the answer.
What should be the thought process when solving this problem? I know how to solve it, but how do you know how to solve it? You can’t just find an equation where you have all of the known values except for 1.
Mathematics news on Phys.org
..., in other words, you ARE LEARNING. You improve through study and practice. You are doing this now.
What did you do to solve the example problem? Made a drawing or diagram, labeled some parts with values, expressions, numbers, picked the mathematical rules you may need to follow, wrote equations for everything you could, decided which equations you needed, and solved for unknown variables.
Likes ProfuselyQuarky, DS2C, QuantumQuest and 1 other person
Perhaps you are relying too much on the numbers. You were asked to find the rate of change of the distance between the boats at time 7. There's nothing special about 7, so why not try to find the rate of change of distance at time ##t##? How do you do that?
1) You find the distance between the objects at time ##t##.
a) Find the position of the first object at time ##t##
b) Find the position of the second object at time ##t##
c) Calculate the distance between these points.
2) You differentiate that (wrt ##t##).
3) You plug in ##t = 7##.
That would be my thought processes on this question - or any question that asks the rate of change of distance between two moving objects.
Edited
PeroK said:
0) Draw a diagram that represents the situation.
1) You find the distance between the objects at time t.
a) Find the position of the first object at time t
b) Find the position of the second object at time t
2) You differentiate that (wrt t).
3) You plug in t=7.
Mark44 said:
Edited
I did do a diagram, but somehow that slipped my memory when I wrote down the steps!
I trust that you did, PeroK, but this is something that beginning students are often reluctant to do, for one reason or another.
Likes FactChecker
The fact that you presented this example as a word problem gives a clue about the possible trouble. It is too hard to formulate a solution approach while looking at the word problem. The first step is to translate the words into equations, using place-holder variables where needed. Once you see the structure of the equations and diagrams, there may be simplification steps and a general approach that will be apparent. Baby steps and practice will get it done.
I don't think you can find general methods to approach all problems without running into Godel-type results; infinitely-many possible problems, finitely-many methods to consider.
Related to Longer math and physics problems
1. What makes math and physics problems "longer"?
Longer math and physics problems typically require multiple steps to solve, involve complex calculations or concepts, and may involve multiple variables or unknowns.
2. How can I approach longer math and physics problems?
The most effective approach to longer math and physics problems is to break them down into smaller, more manageable parts. Start by identifying the given information and what is being asked for, then use known equations and principles to solve for unknown variables step by step.
3. Are there any specific strategies or techniques for solving longer math and physics problems?
Yes, there are several strategies that can be helpful when solving longer math and physics problems. These include drawing diagrams or visual aids, organizing and labeling equations, using units and dimensional analysis, and checking for reasonableness and accuracy of the final answer.
4. How can I improve my problem-solving skills for longer math and physics problems?
The best way to improve your problem-solving skills for longer math and physics problems is through practice. Work through a variety of problems, starting with simpler ones and gradually increasing in complexity. Also, try to understand the underlying principles and concepts rather than just memorizing equations.
5. What resources are available for help with longer math and physics problems?
There are many resources available for help with longer math and physics problems, including textbooks, online tutorials and videos, practice problems and worksheets, and study groups or tutoring services. It's important to find a resource that fits your learning style and offers clear explanations and examples.
  • General Math
  • General Math
  • General Math
