Longest geometric progression that can be obtained from a given set
In summary, I think you might be looking for a sequence that has the largest number of terms possible. This can be done by finding a geometric progression with all of its terms included in the set {100,...,1000}. However, this might not be possible as there might not be a rational number with 1000 as its final number.
Physics lover
249
25
The longest geometric progression that can be obtained from the set
{100,101,102,....,1000}
N/A
I am searching for an easy solution to such questions.I have been playing with it for few hours.I can only make a guess because I don't know how to solve such type of questions.Although I tried assuming first term as 'a',common difference as 'r'.And then the last term that is 'arn-1'should be lass than 1000.And common difference should be less than 10.But it didn't helped a lot.Please help.Thanks
Likes etotheipi
anyone?
Physics lover said:
Homework Statement:: The longest geometric progression that can be obtained from the set
{100,101,102,...,1000}
Relevant Equations:: N/A
Is 100 the first term in the geometric sequence, and is 1000 the last term?
What is the significance of the numbers in between; i.e., 101, 102, ..., 999?
I think you might be confusing geometric progression and arithmetic progression. In a geometric progression, r is common ratio, not the common difference.
Example of arithmetic progression: 1, 4, 7, 10, ... Here A = 1 and d = 3
Example of geometric progression: 2, 1, 1/2, 1/4, ... Here A = 2, and r = 1/2
Likes dextercioby
I think the idea is to create a geometric sequence with the highest possible number of terms such that each term ##u_n \in \mathbb{Z} \cap [100, 1000]##. As in a possible sequence might be '##104, 260, 650##'. It seems like quite an interesting question and I'm not actually sure how to best go about it!
Likes scottdave
A geometric sequence (or progression) has the form ##\{ar^n \}##, where n = 0, 1, 2, ... For the sequence you show, what is the common ratio r?
For my example it's a common ratio of ##2.5##. Since it wasn't stated otherwise in the question I think the implication is that any rational common ratio is permissible!
But I'm not saying my sequence is anywhere near an answer, just an example of a 'valid' sequence.
Yes,100 is the first term and 1000 is the last.Sorry for writing common difference,that was a typo.I will try to make the question a little more clear.We need to find a geometric progression whose all terms are included in the set {100,...,1000} and it has largest number of terms.
Are you sure this is the intended interpretation?
does not necessarily imply
If 100 is the first number in the (geometric) progress, and 1000 is the last, then you have two equations:
##ar^0 = 100## and ##ar^n = 1000##
Solving the first gives a = 100. Substituting for a in the 2nd equation gives ##100r^n = 1000##, or ##r^n = 10##.
As @etotheipi said, there might not be a solution amongst the rationals for r with 1000 as the final number. You might need to fiddle with the first or last numbers in the progression for rational values of r.
I think you did not understood the question.Okay,Let me explain it in detail.First of all,we do not need 100 as the first and 1000 as the last term in G.P.First term can be any term in between 100 and 1000 and similarly the last term is also between 100 and 1000.So we need to find such a progression which has maximum number of terms and all terms should be in this set.I think it will be clear now.
You said this a few posts back:
I answered on the basis of what you wrote. If ##a## is different from 100, and ##ar^{n-1}## is different from 1000, you would still do what I described in my earlier post.
ok.I think there is only a single method to solve such questions.
If you start with ##a## being any number from 100 to 125, and ##r=2##, then the length of the geometric sequence is 4. For instance, with ##a=100## and ##r=2##, the progression is: 100, 200, 400, 800. Length of 4.
If you use a rational, ##r=\dfrac p q##, such that ## 1<r<2## the geometric progression grows more slowly, and it's possible that you may have a longer progression. But this also complicates the task. For ##r=\dfrac p q##, reduced to lowest terms, to have ##a\cdot r^n## be an integer, ##a## must have at least ##n## factors of ##q##
Did you follow the link given by @archaic ? It gives a progression of length 6 starting at 128 with ##r=\dfrac 3 2##.
yes i saw it and that was a brilliant solution.But I think it will not work for larger sets of number.Foe eg- consider {10,11,12,...,10000}.It would take a lot of time if we go by that method.But I think there's no other choice.
[10,10000] is quite easy. Harder is something like [1000,10000].
We will always choose q=p-1, yes?
For [1000,10000] and a trial n up to 5 we can take a=1. E.g.for n=5, p=6, q=5 and qn>1000.
Thereafter we can try values of n and p, assuming at first that a=1.
n=6, p=4
n=8, p=3
n=13, p=2
No point in trying n=7 because p is still 3, etc? Not sure..
For these I get the solutions:
p. a. n
4. 2. 6
3. 4. 5
2 1000 3
E.g. the first of those goes 2.36, 2.35.4, 2.34.42 ..., 2.46
Likes SammyS and Physics lover
Related to Longest geometric progression that can be obtained from a given set
1. What is a geometric progression?
A geometric progression is a sequence of numbers where each term is obtained by multiplying the previous term by a constant ratio.
2. How is the longest geometric progression determined from a given set?
The longest geometric progression from a given set is determined by finding the largest number of terms that follow a constant ratio.
3. Can a set have more than one longest geometric progression?
Yes, a set can have multiple longest geometric progressions if there are multiple sequences of numbers that follow a constant ratio and have the same number of terms.
4. Is the longest geometric progression always unique?
No, the longest geometric progression may not always be unique. It depends on the set of numbers and whether there are multiple sequences that follow a constant ratio and have the same number of terms.
5. How is the longest geometric progression useful in mathematics?
The longest geometric progression is useful in mathematics for its application in number theory, algebra, and geometry. It also has practical applications in fields such as finance, physics, and computer science.
17K
  • Other Physics Topics
13K
  • Art, Music, History, and Linguistics
  • Linear and Abstract Algebra
