Loren Booda
- 3,125
- 4
What has been the longest photon wavelength actually observed?
Loren Booda said:What has been the longest photon wavelength actually observed?
But does it say anything about what has actually been observed or detected.Crosson said:Phrak is on the right track, according to pg 7 of Jackson 3rd edition which contains a discussion on the experimental lower bound for the mass of the photon and refers to Schuman resonances in the earth-ionosphere cavity that have frequencies as low as 8 Hz.
RandallB said:But does it say anything about what has actually been observed or detected.
lightarrow said:Anyway, we shouldn't mix the concept of photon with that of EM waves; having been able to detect very lof frequency EM waves, doesn't imply that we have experimentally proved the existence of photons of such frequency.
Because to say to have detected photons you have to show photoelectric effect, Compton effect, photon antibunching, ecc., not simply a resonance in your electronic circuit.Phrak said:Why not?
lightarrow said:Because to say to have detected photons you have to show photoelectric effect, Compton effect, photon antibunching, ecc., not simply a resonance in your electronic circuit.
RandallB said:So the LONGEST so far is about 150 Khz (about 2 km).
Ok, but AFAIK, also a semi-classical theory (EM wave treated classically - material treated quantistically) could explain the effect, so that effect wouldn't be a conclusive prove that EM radiation of those frequencies is made of photons.Count Iblis said:Ok, so we should make a superconducting LC circuit with some resonance frequency omega, which has energy levels (n+1/2) hbar omega. You can connect an antenna to it and let it absorb one quantum of the electromagnetic field of frequency omega.
The longest photon wavelength observed is approximately 1.2 millimeters, which corresponds to a frequency of about 250 gigahertz.
The longest photon wavelength observed was measured using radio telescopes, which are able to detect low energy electromagnetic radiation such as radio waves.
The longest photon wavelengths are emitted by objects with very low temperatures, such as gas clouds in interstellar space or the cosmic microwave background radiation.
No, the longest photon wavelength observed falls within the radio wave spectrum, which is not visible to the human eye.
Studying the longest photon wavelength observed can provide valuable insights into the properties of distant objects and the origins of the universe, as well as helping to improve our understanding of electromagnetic radiation and its behavior in different environments.
