Longitudinal resistivity in the Quantum Hall Effect
In summary, the Quantum Hall effect is a phenomenon that occurs in materials when a magnetic field is applied, and it results in the resistivity and conductivity being zero. The resistivity and conductivity are connected through the matrix relation \rho^{-1} = \sigma, and the effect that the diagonal components of the resistivity remain zero is what makes the Quantum Hall effect so special.
Spectrum20
My only problem with a basic conceptual understanding of the Quantum Hall Effect is the relation between longitudinal conductivity and resistivity when the magnetic field is such that the filling factor is an integer, and the Hall resistance is quantized. I fully understand the splitting of the 2D DOS into Landau levels, and can see why the longitudinal conductivity will go to zero since the Fermi level is now at an energy where the DOS is approximately zero.
My confusion is that the longitudinal resistivity also goes to zero. In reading the literature, one can often see in the same paper, plots of ro_xx and sigma_xx as functions of magnetic field, and both show the zeros at the same fields! Perhaps I do not understand the physics behind:
sigma_xx = ro_xx / (ro_xx^2 + ro_xy^2)
Which clearly explains ro_xx = 0 implying sigma_xx. But fundamentally, how can resistivity AND conductivity be zero? Thanks for any light someone can shed.
Well, that is sort of beauty of the quantum Hall effect. The resistivity [itex]\rho[/itex] and conductivity [itex]\sigma[/itex] are really connected through the matrix relation
[tex]\rho^{-1} = \sigma[/tex]
which comes from the relations
[itex]\mathbf{E} = \mathbf{\rho}\cdot\mathbf{J}[/itex]
[itex]\mathbf{J} = \mathbf{\sigma}\cdot\mathbf{E}[/itex]
In the end, the conductivity is simply defined as the inverse of the resistivity (or vice versa).
So in principle, the resistivity and conductivity are tensors, namely
[tex]\rho = \begin{pmatrix} \rho_{xx} & \rho_{xy}\\ \rho_{yx} & \rho_{yy}\end{pmatrix}[/itex]
[tex]\sigma= \begin{pmatrix} \sigma_{xx} & \sigma_{xy}\\ \sigma_{yx} & \sigma_{yy}\end{pmatrix}[/itex]
On top of that, the matrices are each others inverse. But the inverse of any 2x2 matrix is always
[tex]\sigma^{-1} = \frac{1}{\det(\mathbf{A})} \begin{pmatrix} \sigma_{yy} & -\sigma_{xy}\\ -\sigma{yx} & \sigma_{xx}\end{pmatrix}[/tex]
with [itex]\det(\mathbf{A}) = \sigma_{xx}\sigma_{yy} - \sigma_{xy}\sigma_{yx} = \sigma_{xx}^2-\sigma_{xy}^2[/itex]. That last equation arises due to isotropy of the sample.
So this explains the very general relation you have written down. Note that when you have an off-diagonal structure for the conductivity tensor (i.e. all diagonal elements are zero, but the off-diagonals are not), then the resistivity is automatically also off-diagonal. It still has non-zero off-diagonal components though, so saying that the resistivity is zero is simply wrong.
In "normal" metals you would expect that the response of the system, which is the current, is in the same direction as the applied electric field -- this is simply Ohm's law. But here, the Hall effect comes into play: the magnetic field acts as a Lorentz force, and causes the response current to be aligned perpindicular to the electric field. The presence of the magnetic field always causes the effect that there are some off-diagonal components. What makes the Quantum Hall effect so special is that a mechanism causes the diagonal components to remain zero -- even though you expect them not to be.
Hope this doesn't create more questions for you... ;)
Thanks for the response, xepma. That clears up the mathematical side of things a little bit, but what would be the response to an electric field applied longitudinally? Since ro_xx and sigma_xx are both zero if we have an appropriate filling factor, do we have current? Thanks.
Related to Longitudinal resistivity in the Quantum Hall Effect
1. What is the Quantum Hall Effect?
The Quantum Hall Effect (QHE) is a phenomenon in condensed matter physics where a two-dimensional electron gas (2DEG) subjected to a strong magnetic field exhibits quantization of its Hall resistance. In simple terms, it describes the behavior of electrons in a thin layer of material when subjected to a strong magnetic field.
2. What is longitudinal resistivity in the Quantum Hall Effect?
Longitudinal resistivity is the resistance of a material in the direction of the electric current. In the context of the Quantum Hall Effect, it refers to the resistance measured in the direction parallel to the magnetic field. This value remains constant and does not exhibit quantization, unlike the Hall resistance.
3. How is longitudinal resistivity measured in the Quantum Hall Effect?
Longitudinal resistivity can be measured by applying a constant current to the material and measuring the voltage drop in the same direction. This value is then used to calculate the longitudinal resistivity using Ohm's law (ρ = V/I).
4. What causes the quantization of Hall resistance in the Quantum Hall Effect?
The quantization of Hall resistance in the Quantum Hall Effect is caused by the formation of Landau levels, which are discrete energy levels that electrons can occupy in a magnetic field. The energy levels for electrons moving in the direction perpendicular to the magnetic field become quantized, resulting in a quantized Hall resistance.
5. What are the applications of the Quantum Hall Effect?
The Quantum Hall Effect has many practical applications, including the precise measurement of electrical resistance, the realization of a resistance standard, and the development of new semiconductor devices. It also has potential applications in quantum computing and the study of topological states of matter.
  • Quantum Physics
  • Atomic and Condensed Matter
