MHB Looking Answer About Area of Circle.
  • Thread starter Thread starter susanto3311
    Area Circle
The discussion focuses on finding a formula to solve a multiple-choice question regarding the area of a circle. The area of a sector is calculated using the formula A_s = (θ/360)πr², where θ represents the angle of the sector. Participants clarify that the answer of 462 pertains to the area of the sector, not the remaining area of the circle after the sector is removed. There is some confusion about whether the question asks for the area of the cut-out sector or the remaining portion. The conversation emphasizes the need for clarity in the question to avoid misinterpretation.
susanto3311
hello all...
i'am looking for a formula to solve this multiple choice question about area of circle...
like my picture below ...
any body can help me, thanks in advance...
susanto3311
Mathematics news on Phys.org
susanto3311 said:
hello all...
susanto3311
The area of the bit of the circle left will be area of the whole circle less the area of the cut out sector. The formulae for the area of a sector (in degrees) is given by
$$A_s = \dfrac{\theta}{360} \pi r^2$$
In this case $$\theta$$ is the angle of the sector (i.e. the missing piece in your example)
the answer is 462...do you agree?
I get B as my answer (although the question could stand to be clearer about whether or not it wants the area of the cut out sector or the area of "pacman" - the bit that's left).
How did you arrive at 462 (which is the area of the sector)? Don't forget that's just the area of the sector - you need to subtract this from the area of the whole
hi super...
thanks. i'am missing you are right...
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
