Looking for a chemical with a boiling point between 10C and 50C
The discussion focuses on identifying a chemical compound with a boiling or condensation temperature between 10°C and 50°C at standard pressure, preferably organic and low in toxicity, for a theoretical exploration of temperature changes in a medium temperature heat storage device. Participants suggest various candidates, including pentane, diethyl ether, and dichloromethane, while noting their flammability and potential hazards. Acetone and other compounds with boiling points above 50°C are deemed unsuitable. Concerns about toxicity and carcinogenicity are raised, leading to recommendations for safer alternatives with higher boiling points like methyl t-butyl ether and methanol. The conversation emphasizes the need for a sensible example that avoids dangerous substances while facilitating a meaningful discussion on the topic.
Skaperen
TL;DR Summary
i am looking for a chemical with a boiling point between 10C and 50C at standard pressure for a discussion example.
i am looking for a chemical compound that has a boiling or condensation temperature between 10C and 50C at standard pressure and is not one prohibited for discussion in the Physics Forum or any online chemical forums. something that is organic and not very toxic is preferred. it should be something that responds to microwave heating (optimal frequency being known helps). freezing/melting point should be at least 30C below the boiling point.
my purpose for this is to be part of a discussion involving the physical effects of sudden temperature changes in a medium temperature heat storage device. i will not be acquiring this material. i just wish to discuss a sensible example. too bad water requires 100C to boil as it would be a great choice if people didn't need to imagine so much energy. it will be an example in a discussion. but you know how some people are, so i don't want this to be something dangerous.
Chemistry news on Phys.org
A nearly perfect question for chat GPT.
I'll toss out ether as a candidate (with absolutely minimal thought), but... no, I haven't done your research for you. I'm sure there's something wrong with it.
BTW: Acetone was my first guess, but, nope: 56C.
i found Pentane is 36C.
Engineering Toolbox lists quite a few.
Being not a chemist, I can only guess as to which ones fit all your criteria.
I guessed carbon disulfide, but wiki claims that it's a neurotoxin.
I thought diethyl ether might work as it used to be used as an anesthetic, but wiki claims it is also used as a starter fluid for diesel engines, so I'm guessing it's flammable.
The rest all have scary names which I wouldn't go near. But as I said, I'm not a chemist, and chemistry has always been my worst subject.
product°C
1,2-Butadiene10.9
Ethylamine16.6
Hydrofluoric Acid18.9
Acetaldehyde CH3CHO20.8
Trichlorofluoromethane refrigerant R-1123.8
Isopentane27.8
1 - Pentene30
Isoprene34.1
Diethyl ether34.4
Ether34.6
n - Pentane36
Dimethyl sulfide37.3
Ethyl bromide C2H3Br38.4
Methylene Chloride(CH2Cl2, dichloromethane)39.8
Methyl iodide42.6
Carbon Disulfide CS246.2
Propylamine47.2
Carbon Bisulfide47.8
Propanal48
Cyclopentane49.3
Neohexane49.7
I suggest pentane, diethyl ether, chloroethane (bp 12.3 C), and dichloromethane.
Pentane and diethyl ether are highly flammable, you might want to avoid them.
Some you listed are smelly (e.g. acetaldehyde, propylamine, propanal).
Some are dangerous. Don't use hydrogen fluoride or carbon disulfide.
If I were in your place, I would use dichloromethane. I have used it myself for many years.
Recently people are saying it is carcinogenic (as are several compounds on your list).
If that is a problem, I would recommend seeing if you can use a higher bp.
Use acetone (bp 56 C), methyl t-butyl ether (bp 56 C), methyl acetate (bp 57 C),
or methanol (bp 65 C).
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
