- #36
turbo
- 56
You might want to make a prototype block, using a small solenoid to apply the clamping force. Drill a hole through the block and mount the solenoid so that when activated, its ram presses radially inward. The brake shoe could be as simple as a cylinder of teflon threaded onto the ram with a bit of rubber epoxied to the end. When power is discontinued, the solenoid retracts and the block slides freely. If I'm imagining this correctly, you will want the block to actuate a switch that shuts off power to the solenoid when the block hits its lower limit, then the solenoid ram will retract and the spring will pull the block back to the upper limit. If you have a machine shop and can prototype this block, you will have a chance to refine it before contracting for a production run.
Note: I said production run, because what you're asking for probably does not exist in a form that you would find usable. Your best bet is to prototype it, then get bids for a production run large enough to fill your needs and large enough to keep the per-unit cost down.
