Looking for deductions to find the angle between vectors
In summary: B-\theta_A| .In summary, the conversation discusses the derivation of the cosine and sine between two vectors using the dot product and trigonometry. The cosine is given by the dot product divided by the magnitudes of the vectors, and the sine can be derived using the trigonometric identity. The notation for the angle between two vectors is also discussed, with the text using the minimal angle between the vectors.
opus
131
I have a question in my text (Intro Mechanics by Kleppner) and a question is to find the cosine and sine between two vectors.
It gives me the cosine piece: $$\cos(\vec A, \vec B) = \frac{\vec A ⋅\vec B}{|A||B|}$$ which I assume is just from the dot product, but it has no derivation of this, and doesn't mention it for sine.
I've looked around Google for derivations of this, but only find worked examples of problems like the one I have given. Could anyone reference me to the derivations for these?
Mathematics news on Phys.org
In what form do you know the definitions of the dot and cross product of two vectors? If you know them in terms of the angle between the vectors, use that. If you know them only in terms of multiplication of the components (e.g. A.B = AxBx + AyBy + AzBz) then you can draw some triangles and use trigonometry to rewrite A.B in terms of |A|, |B| and the angle between A and B. I would start with 2D vectors because the trig is much simpler, and an answer that works in 2D that doesn't specifically involve the components or Cartesian angles must look the same in 3D (or any D).
Likes opus
In terms of dot product, I know we can use either ##\vec A⋅\vec B = |A||B|\cos(\theta)## or also ##\vec A ⋅ \vec B = A_1B_1+A_2B_2+A_3B_3##
For the cross product, I derive this by crossing ##\vec A_xi## with ##\vec B## and then cyclically permuting through x,y,z i,j,k to find the other terms.
Not entirely sure of what you mean with the triangles, but I'll try to work something out with that and see what I get.
So, you want to go from:
To:
Likes opus
To:
Yes, just came up with this. Got tripped up for a second on how the book has it labeled as ##\cos(\vec A, \vec B)##
Still working on the sine piece. Currently trying to derive it by using the fact that the magnitude of the cross product of A and B is the area of a parallelogram and go from there.
Although you have the possibility of using the cross product and it to some extent may be easier. If you just want the sine and you have the cosine there is a nice trigonometric identity to use ...
In more general vector spaces equipped with an inner product, the angle is defined through the relation you gave in #1.
Likes opus
I think I may be following.
##\sin^2(\theta)+\cos^2(\theta)=1##
##\implies \sin(\vec A,\vec B) = \sqrt{1-\cos^2(\vec A, \vec B)}##
The right side should be ##\pm \sqrt{1-\cos^2(\vec A, \vec B)}##, where you choose the appropriate sign according to the angle between the two vectors. I.e., if ##0 \le \theta \le \pi## then ##\sin(\theta) \ge 0##, and if ##\pi \le \theta \le 2\pi##, then ##\sin(\theta) \le 0##. And similar for other ranges of angles.
Also, the notation can be appreciably simplified if you simply define ##\theta## as the angle between the two vectors.
Likes opus
Typically ”the angle between two vectors” refers to the minimal angle of rotation necessary to rotate one to be parallel to the other. This angle is always between zero and pi and therefore the ##\pm## is not necessary in this case.
Likes opus
Yes, there is an ambiguity in the notation [itex]\sin(\vec A,\vec B)[/itex] since [itex]\sin\theta[/itex] is an odd-function of [itex]\theta [/itex]. Of course, [itex]\cos\theta[/itex] is an even function.
Given two vectors [itex]\vec A [/itex] and [itex]\vec B [/itex],
one might interested in "the [non-negative] angle-between-the-vectors" [itex] |\theta_B-\theta_A| [/itex]
or the "[signed] angle from [itex]\vec A [/itex] to [itex]\vec B [/itex]" [itex] (\theta_B-\theta_A) [/itex] , for example when talking about torque (and wanting the sense, directly) or when writing a computer program.
Since you are following Kleppner's text (and potentially higher-level textbooks),
I suggest you use the signed-angle as a definition [and make that clear],
dropping back into its magnitude as you need to.
This is similar to using displacement as a definition, and [say] distance as a special case (as needed).
Likes opus
Very helpful everyone, thank you.
Is your question one of wanting to know how to go from (1) to (2) below, or vice-versa?
$$ \begin{array}{cclr}
{\bf A} \cdot {\bf B} &=& A_1 B_1 + A_2 B_2 + A_3 B_3& \hspace{3ex}(1)\\
{\bf A} \cdot {\bf B} & =& |{\bf A}| | {\bf B}| \cos \theta & \hspace{3ex}(2)
\end{array}$$
Well, both forms are unchanged under a rotation, so that if ##{\bf A}' = R {\bf A}## and ##{\bf B}' = R {\bf B}## for a rotation ##R##, we have ##|{\bf A}'| = |{\bf A}|##, etc, and
$$ {\bf A}' \cdot {\bf B}' = {\bf A} \cdot {\bf B}$$ for either way (1) or (2) of defining the dot product.
So, if we rotate the vectors until ##{\bf A}'## points along the ##x_1 -## axis and ##{\bf B}'## lies in the ##x_1\; x_2 -## plane, and letting ##A = |{\bf A}|, B = |{\bf B}|## we have
$${\bf A}' = (A,0,0), \: {\bf B}' = (B \cos \theta, B \sin \theta, 0),$$ so that ##\sum_i A_i B_1 = \sum_i A'_i B'_i = AB \cos \theta.##
Likes opus
\end{array}$$
The cosine forms were clear, it was the sin form that confused me at first, but I've got them now. But now that you mention it, I'm not sure what you mean on "change under rotation". Are you referring to how when the derivative of a vector is taken and the magnitude remains constant, that it can only rotate?
Related to Looking for deductions to find the angle between vectors
1. How do I find the angle between two vectors?
To find the angle between two vectors, you can use the dot product formula: θ = cos^-1((a · b) / (|a| * |b|)). This formula calculates the cosine of the angle between the two vectors, and then uses the inverse cosine function to find the angle in radians.
2. Can I use the cross product to find the angle between vectors?
No, the cross product is used to find the magnitude and direction of a vector perpendicular to two given vectors. It does not directly give the angle between the two vectors.
3. What if the vectors are in different dimensions?
If the vectors are in different dimensions, you can still use the dot product formula to find the angle between them. Simply add zeros to the shorter vector to make it the same dimension as the longer vector.
4. Is there a specific unit for the angle between vectors?
The angle between vectors is usually measured in radians, but it can also be measured in degrees. Just make sure to convert the angle to the desired unit when using the formula.
5. Can I use this formula for more than two vectors?
No, this formula only applies to finding the angle between two vectors. If you have more than two vectors, you will need to find the angle between each pair of vectors separately.
  • Linear and Abstract Algebra
  • General Math
  • Classical Physics
