Looking for information on Celanese Fortiflex polymer
In summary, Celanese Fortiflex was a type of high-density polyethylene (HDPE) used in TRIGA nuclear reactors in the 1960s. It was known for its durability and ability to withstand high levels of radiation. However, it was later found to have durability issues and is no longer in use. There is limited information available on it, but data sheets and some articles can be found online.
mesa
38
Hey guys, I am trying to located more information on a polymer that was called celanese fortiflex. It was used in TRIGA nuclear reactors to hold samples in a high neutron flux and was developed (I believe) around the early 1960's.
Some modern PE materials have been tested, but fall apart after less than a week in a thermal-epithermal 10^12 neutron / cm^2*s environment.
Any help would be appreciated!
Likes davefarrell60
It appears that Celanese Fortiflex was nothing special.
You might find the data on the web. But you can buy the data sheet.
https://www.amazon.com/dp/B00B5KNPB0/?tag=pfamazon01-20
Also:
“Fortiflex” [Celanese] Detailed information: TM for a high-density polyethylene consisting mainly of long molecules with occasional short side branches. Thermoplastic.
Properties: Milk-white, translucent pellets (colors are also available). D 0.95; melt index 0.2–8; tensile strength 3100–3700 psi; highest use temperature 225F. Combustible. See Polyethylene.
Fortiflex was a PE-MD or PE-HD made by Soltex Polymer Corp.
Re: Durability of Celanese Fortiflex.
http://retrochalet.blogspot.com.au/p/russel-wright-idealware-and-toy-dishes.html
"Newspapers were abuzz with the fact that Fortiflex (a Celanese Plastic) would be used. Proven to withstand tests of "boiling" it was guaranteed to be used from freezer to table. Marketed to adults, it was NOT the same plastic as the hard styrene toy dishes were. "
"Fortiflex's plastic Idealware pieces were made of polyethylene resembling the look and feel of a fancy Tupperware. Ironically though, over time the mixture became brittle, and unlike the early Tupperware pieces you may find now, it did not have a waxy feel to it. "
FAQ: Looking for information on Celanese Fortiflex polymer
1. What is Celanese Fortiflex polymer?
Celanese Fortiflex polymer is a type of thermoplastic polymer that is known for its high strength, durability, and flexibility. It is commonly used in a variety of industries, including automotive, construction, and consumer goods.
2. How is Celanese Fortiflex polymer made?
Celanese Fortiflex polymer is made through a process called polymerization, in which monomers are chemically bonded together to form long chains. These chains are then processed and shaped into the desired form for use in different applications.
3. What are the properties of Celanese Fortiflex polymer?
Celanese Fortiflex polymer has several notable properties, including high impact resistance, chemical resistance, and low moisture absorption. It is also lightweight and has good dimensional stability, making it a versatile material for various purposes.
4. What are the applications of Celanese Fortiflex polymer?
Celanese Fortiflex polymer has a wide range of applications, including in the production of automotive parts, electronic devices, and household items such as containers and packaging. It is also used in the construction industry for pipes, flooring, and roofing materials.
5. Is Celanese Fortiflex polymer environmentally friendly?
As with any material, the environmental impact of Celanese Fortiflex polymer depends on its production and disposal processes. However, it is generally considered to be a sustainable and eco-friendly option compared to other materials, as it can be recycled and has a long lifespan, reducing the need for frequent replacement.
